Victor under a Firebird hood
looking for opinions if it will go under a 69 Firebird hood.
I will be going from a T2 with a 1" spacer and 850 Holley, to a Victor, no spacer and a 1050 dominator. I do have a 2" cowl that should help a bit.
69 Firebird 472, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 10.90 @123 |
I had a Victor, one inch spacer, and a Dominator when I first got my car, but I believe my cowl is 3.5 to 4 inches.
Whitmore 462, 670 heads 10.55@125 Same with 310 E D-ports 10.12@131 498 w/single 88 8.53@158 |
Have a friend with one under a 68 stock bird hood with a drop base AC.Tom
Have a Victor, Dominator, 1/2 n2o plate, and 2 1/2" K&N filter. Just touches hood when shut. Have a 4" cowl on 67' Bird
Brian
Boobs & bacon |
I tried a Victor with a Q-jet (no spacer) and it barely fit under my OEM 400 hood. It was a pig, I suspect a spacer would have helped. I switched to a Tomahawk with a 1" spacer and it ran much better, and there was room to spare. Now I run a T-II with a 1" spacer, 850 DP Holley, and it barely fits under the same 400 style hood. I will never run a hood scoop or cowl hood on this car...I like the OEM look.
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Tom, by any chance you got a picture of your friends car under hood?
A fwiw. On the Year One Bandit Trans Am project with a 535 combo Jim Butler used a Victor intake with the carb flange milled down 0.650" to help it fit under the hood. With the cut down intake he used a WFO drop base unit for the TA Shaker scoop. Tested on the engine dyno at peak power rpm it gave up about 15 hp by milling the intake. On my current 505 street engine I did the same thing with a Victor intake & HP950 carb. On the dyno I lost about 8-10 hp at peak power rpm after milling the intake flange 0.650". Not a race deal so for me I don't miss the 8-10 hp, the engine made 660 hp at 6000 rpm.
I will get one.He was going to be at the pontiac show this sat but had to leave town.Tom
I can text pics.text me at 5622430570
is that one a little shorter compared to a milled Victor? did you notice any change in output at the lower rpm range? figured if you lost a little up top, did it help down low? |
I had my 4150 Northwind with a 3/8" spacer and a flat topped drop base air cleaner with a 3" filter under my OE 400 hood. The Victor is about 1 1/4" taller than the Northwind according to this: http://www.tinindianperformance.com/...-measurements/
'68 Firebird 463/pump gas/SD 325 E-heads/266-272 SR cam/1050 Dominator/3.73/ET Street Radials/1.37 60'/6.30@108.80/9.93@135.14 Hot Rod Drag Week finishing averages: 2014 - 11.12 @ 118.56 2015 - 10.84 @ 124.97 2016 - 10.56 @ 127.88 2017 - 10.29 @ 130.74 2018 - 10.29 @ 130.53 2019 - 10.16 @ 132.34 2021 - 10.09 @ 132.69 2022 - 10.13 @ 133.07 9.93 run - https://youtu.be/hII0_UlYM4U |
going by those measurements, it`s going to be about 1.3/4" taller than my T2. so hopefully with a 2" drop base it will be ok
