1970 Judge Wing
Hey Guys I just picked up a 1970 GTO Judge Rear Wing locally that a guy had and even had the original Box! It has the lines underneath and a small 1/8 Hole drilled in the bottom, My ? is how should my body guy prep this, Leave the hole there for moisture to escape. Also looks like plug marks underneath as well. I did ask him to find the box for me & he said he will look. It does look like a factory unit and the studs have a Blue plastic covering on them. I lucked out cause this is brand new! I will try & post Pics.
1970 GTO Judge. New times 10.60/126 with a 1.45 60ft. 2002 FIREHAWK-conv. 6-sd. 1969 Carousel red Judge Ram Air IV 722 heads. 4-sd. Black interior. |
70 Wing
Leave the hole alone. It's more for pressure relief than a moisture escape. Dressing down the plug marks and using filler to smooth it all out just makes everything look correct.
I would disagree Mike - the originals were not finished smooth on the bottom.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
Sorry, I was talking about the ground down plugs, not filling in the lines.
Thanks guys, I will definitely look closer to the next wing underneath I see on another GTO
