New best
Finally made it to the track this past weekend, first run since I changed up the rear gears from 3.50 to 3.89 and converter from 3200 stall to 4300 stall. Times as follows:
60' new 1.53, old best 1.68 1/4 new 11.23 at 118.2, old best 11.39 at 117.6 Extremely hot and 98 degrees with humidity Total weight with me in it 4300 #. With some tuning etc. hope to hit high 10's |
wow! what convertor? congrats! easy tens in good air
I sent my old ten inch back to Peter at Continental for re stall, sayed he kept it a tight as possible, and he is right driving on the street no real difference. I also have to get used to the 3.89 as the RPMS come up real quick trying to shift at 5900 and I hit the rev limiter ( 6300 ) out of first, going thru the traps at about 6050 rpm instead of 5500 before.
Well, just based on you're 60' increase alone you should be right at 11.19 or a little better, maybe 11.15. Whatever you pick up in 60" you should be 2-2.5 better at 1320. That's a good increase and 10's may be just around the corner. Congrats in the new best, good job!
QUICK-CHANGE RESTRICTOR PLATES FOR INDEX RACING WWW.RESTRICTORPLATE.COM Thanks to our sponsors,
Hoosier tires, Be Cool Radiators, K&N Filters, Scat, Jesel, Les Schwab Tires, ATO Transmissions |
What rear tire u running? I have contemplated about sending mine back in for another re stall closer to 4-4200, just not sure how well it will work with my current 3.42 gearing on the street. track I am not worried .
I am running MT 275/60 street et radials at 18.5#, adjustable upper and lowers, Spohn ARB, double adjustable QA1 rear shocks and single adjustable QA1 (coil over conversion type) in the front.
Deno |
Congrats!
congrats!
nice
1980 TA 455 th400 2.56 posi 12.27@111.48 http://www.dragtimes.com/Pontiac-Tra...lip-29967.html http://www.youtube.com/watch?v=6X5XJ9PR1Qw https://www.youtube.com/user/hal101/videos |
Congrats!
Conrad 79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers. |
whats the rest of the combo?
Sorry I was out of the office..oops, I was busy. The motor is a 535 IAII, 330 cfm SD heads, victor intake (non ported) 1000 HP Holley, 1 7/8" Dougs headers, 3 1/2 exhaust into dumps (open), cam is Comp solid 254/254 .640 lift.
Deno |
What track did you run it at?
"I have contemplated about sending mine back in for another re stall closer to 4-4200, just not sure how well it will work with my current 3.42 gearing on the street. track I am not worried ."
Darby, that was my recomendation at the time, and it will work fine with 3.42 gears on the street at your vehicle weight. You already ditched the dual plane intake and q-jet, so why worry about fuel economy and efficiency? Get the 4200 stall deal and go faster!.....Cliff
Grandbend Motorplex, Ontario
If you continue to use the T-II intake, it's going to LOVE the 4200 stall version of the Continental 10" converter.
Getting heavy street/strip cars to run really quick is easier when your get them to move out of the gate hard enough to give the driver a nosebleed! That leave "soft" finish "hard" stuff requires a LOT of top end charge, which means big HP and lots of RPM's. It's up to you to get it too hook, but when you do hook it up with mid 1.5 60' times, every single run will be well into the 11's with as much power as your new engine makes!.....Cliff
very nice... congrats!!
1972 Pontiac LeMans Thanks to Fuelab Digital Fuel Delivery Quarter-Max Chassis and Racing Components |
well I decided after this race sunday I am pulling the convertor and sending it back to chris for a restall closer to 4-4200 this time!... I am only 2 rounds out of fifth place ,but the car wants more stall anyway so well see how I end up at the end of the year.. Will let ya all know how it works at next race on the 29th of aug after restall
