Good information. I will give it a try. |
I once had a 1982 Trans Am (yeah, 305 SBC) I bought new and later converted to a carburetor and HEI. It was bad about being very hard to start hot. The starter would try but the engine seemed to be kicking back. I had bought the HEI out of a junkyard and the mechanical advance was rusty and would stick in the far advanced position. Once I fixed that it was fine.
On the other hand, lots of good advice here about using big cables, good grounds and terminals, and a mini starter.
Kent R. |
Not sure about a 67, but on a 68 that purple wire can be a pain ... it's often roasted pretty good. On a 68 it runs all the way back to the neutral safety switch on the shifter and then back up to the dash ... I've seen them in very burnt condition at the shifter (automatic).
I'm World's Best Hyperbolist !! |
The Following User Says Thank You to dataway For This Useful Post: | ||
I've never had the issue with a stock car! However, I have experienced the issue on modified cars with headers. Generally I put on larger diameter cables, use a mini starter (Robbmc) and a heat barrier on the headers where they are close to the starter.
My money talks to me-it usually says goodbye! |
I cleaned my negative wire. I noticed one thing. The bolt to negative wire is connected to power steering bracket Right behind the alternator. It's always been there since 2000.
My negative wire could use an update. Not sure if that's a good place. FB66 |
See the attached photos in post #20. That's where it should be.
Greg Reid Palmetto, Georgia |
If you're not concerned with originality, you have some options. Since keeping ground wires as short as possible is a best practice, I chose to attach my battery ground cable to the cylinder head on the forward stud rather than the stud between the #1 and #3 cylinders. It allows for less cable length and slightly cleaner routing.
1966 Pontiac GTO (restoration thread) 1998 BMW 328is (track rat) 2023 Subaru Crosstrek Limited (daily) View my photos: Caught in the Wild |
Thanks Z
I like that look FB66 |
Z
Is that 1 gauge wire? |
I don't have a bolt that has the extra threads for the cable.
Where do I get that? FB66 |
Yes, it is 1-gauge wire. I bought them from BatteryCablesUSA.com and ordered them to length with the ends of my choosing crimped on. Very affordable price and they are very high quality.
https://www.batterycablesusa.com/1-g...able-with-ends Not sure where to source the bolt/stud, but I imagine others here will know. I bet people have them sitting in buckets in their garages/shops from engine disassembly, etc.
I actually have my ground cable in the same location...in fact, I'm pretty sure that's the stock location for '68.. I even bolted the positive cable pass-through tube to the same bolt and routed the positive under the block to the starter. I couldn't install it into the normal spot between 5 and 7 because of the RA manifolds.
FB66, do you not have a studded head bolt in the second spot as shown in my photo? My '66 engine doesn't have the first studded bolt either. Only the two on either side of the center exhaust ports. I never noticed that before but they might have changed the ground location sometime between '66 and '68. Sent from my moto g stylus (2021) using Tapatalk
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 08-02-2023 at 12:11 PM. |
This is where my negative is bolted right now. Yellow arrow.
No thread bolt.
There's one in back
Yeah, I'm pretty sure someone put the wrong head bolt there. You should have had at least one more threaded head right between the 1 and 3 plugs. I think they probably moved it to the front for the ground in the later years so they could use the second one for the front end of the exhaust shroud. It's missing on yours and that's why they put ground on the ps bracket.
Whoa. Factory headers, without the rerouted wiring?
There might not be anything wrong with your starter. Extend existing wires with splices if you have to. https://www.amesperf.com/parts/23387/ |
The Following User Says Thank You to 242177P For This Useful Post: | ||
#38
I've been down the heat soak rabbit hole.
My advice is buy a new powemaster 9150 xs torque and all your problems will disappear. Sent from my SM-A426B using Tapatalk
Good eye 242177P.
#40
I guess I am not sure exactly what you are talking about. I do have factory exhaust manifolds. Where should the wire be? I am thinking of getting new 1 gauge wires. Please help me out FB66 |
