#41
I have a few with original motors. The best is our 70 LeMans my parents bought in 75. Has 208k onthe original motor, Trans and rear end.
#42
#43
My '67 GTO has never had it's engine removed, I bought it from the original owner. Currently has around 121k miles on it. I did pull the timing cover off when I bought it to check the timing set, it had already been replaced and I put a new one on anyway.
1999 WS6 Formula, 1 of 175 1967 GTO Linden Green 4 spd, A/C, survivor 1967 Lemans convt 1967 Firebird 400 bench seat, deluxe interior, auto 1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne. 1961 Catalina 2 door htp 1960 Ventura 4 door htp wife's car 1960 B'ville 2 door htp 1960 Catalina Wagon wife's car too |
#44
67 GTO HO - Original 115K miles.... Does not use oil.... does not smoke.... runs mid 14's without me trying to actually blow it up....lol
Motor was removed to repair oil leaks.... replaced Timing Chain, Oil Pump , Crank bearing looked great when we did Rear Main Seal
Troy Rockaway NJ 67 GTO 400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI HOTCHKIS/UMI/BILSTEIN |
#45
70 delta had a 350 2bbl, t400, and a 12bolt. Built like a brick outhouse!
115k miles and able to turn out mid 14s is pretty awesome. My completely stock 4 speed 77 t/a would run low 15s at 93k with the original restrictive original single exhuast feeding the transverse dual exh mufflers. Jay Last edited by Jay S; 01-25-2019 at 08:49 AM. Reason: Edit |
#46
The original 326 out of my wagon is taken apart, in the attic with 293000 miles. It ran well other than a loose timing chain when I pulled it in 1987, for a 455. I am now too old to carry the stuff back down. so I guess it stays up there lol. If I didn't want to build the '66 Tempest into a hot rod, It would still have the original engine in it, I am sure.
#48
Oldsmobile engines were pretty tough engines.
Now that I think about the 76 Delta 88 that my Dad bought after our 70...the 76 (it had a Quadrajet) likely had one of those goofy undesireae Q-Jet's that had the extra metering Rod...no wonder it never seemed to run right!
#49
Mine still has the original Quadrajet.. Fortunately, it is the older style with the flat top, and just the primary and secondary rods. No catalytic converter in '74 either. Only "modification" I have done was block off the EGR, and installed an HEI distributor (and recurved it).
#51
69 Firebird pulled good running original engine (400) and rear at 50.000 to put in a 463 and 12 bolt. I want to have fun till I'm ready to put it back in.
#53
Interesting to see the olds motor mentioned above with no manifold gaskets. My 79 TATA has about 25kon it now andhad a bad exhaust leak. Looked like it had never been touched and did not have ex manifold gaskets on it.
#54
I wish... Spun three main bearings in my original 400 block so bad that the journals turned blue. There's a junkyard 455 in it now out of a Grandville that had about 90k miles on it. Runs smooth as silk.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
#55
Mine has the original 73 bottom end. Heads, cam, intake carb all otherwise. Factory 455's are tough.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
#56
I own a '71-1/2 GT-37 with the original 400 cu in engine with 121,XXX miles. The engine has never been rebuilt and it runs great. It also has the original 3 speed tranny and original 3.55 rear end.
#57
Later, when they rust, pit, or when the manifold warps from age and heat cycles, do they leak. |
#58
Those Olds exhaust manifolds, didn't look like any thought was put into air flow dynamics. Just a conduit to get the exhaust gases out. They had that crossover pipe that ran from one manifold to the other. They had a distinctive exhaust note. I'm sure the factory Olds hot rods had something better....
Makes me wonder IF, the odd ball factory exhaust I'm speaking of, may possibly of had an an in likely performance twist, at least on a stock engine?
#59
My '66 Grand Prix was purchased with a chronically bad running engine. Speedo showed 97k which I later verified as correct. Pulled the engine and we found it had broken ring lands on two pistons but apart from that, absolutely no measurable wear on the crank and the bores only needed lightly honing.
I did not want to go oversize at all, wanted it back to factory original specs. My BIG problem was finding original spec pistons etc. Every source I tried only had upsize pistons, bearings etc. Couldn't believe I wanted to back to stock size. Eventually I got the parts, put it all back together and its now run another 40k without one hiccup (except the rear main is just now starting to leak). Runs super quiet and smooth. I have always used 98RON fuel and I've only ever used diesel oil in it.
To laugh at men of sense is the privilege of fools. |
#60
2001 Yukon Xl with 353000 miles on it with all original accessories and all born with parts. Runs like a brand new one, even shifts good. Now that I’ve bragged on it it will probably blow up but that’s ok because it doesn’t owe me anything. It has hauled my family all over hell and half of Georgia and never a hiccup. The power steering cooler is leaking but not enough to fix yet.
