Old 09-22-2019, 10:21 AM
68hotbird 68hotbird is offline
Default Race engine question 4.5 stroke 4.250 bore or 4.25 stroke 4.350 bore
Looking at combos and wanting opinion. I have a block that is 4.245 I can do either Combo 4.25 stroke bore to 4.350 or use my 4.250 bore and use 4.5 stroke looking for opinion on both combos. Will have high port heads that flow 375-380 ish.
Old 09-22-2019, 10:25 AM
slowbird's Avatar
slowbird slowbird is offline
Bigger bore every time. Also shorter stroke will be easier on rods/pistons
Old 09-22-2019, 11:35 AM
johnta1 johnta1 is online now
That may be true, but bigger CID probably makes more HP?
Old 09-22-2019, 02:22 PM
krisr's Avatar
krisr krisr is offline
Wouldn't the HP output balance out with the extra revs that the shorter stroke should be able to provide? Depends what you're looking for, me personally a shorter stroke bigger bore is my favourite.
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120
'66 Pontiac GTO - 389, 4 speed street cruiser
Old 09-22-2019, 02:49 PM
mgarblik mgarblik is offline
Will this be NA or a power adder engine?
Old 09-22-2019, 04:48 PM
Half-Inch Stud's Avatar
Hmmm yea, using Excel, if you can count you tire roll-out across the 1/4 mile, and multiply the engine turns *4 and * the rear & trans gear & Converter ratio, you would discover the number of Powerstrokes applied.
Then that would reveal the applied power across the 1/4 mile, for combos.
Old 09-22-2019, 05:27 PM
AIR RAM AIR RAM is offline
Agreed, At the end of the day, big bore, short stroke with a boost specific cam with 15-20lbs of boost will be hard to beat!
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 09-22-2019, 07:25 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is offline
What about a 4.375 stroke ?
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 09-22-2019, 10:10 PM
Scott Roberts Scott Roberts is offline
Go with the larger bore.... not that a long arm cant rpm, but it will take more work... if I had to guess Langer turns 9200 rpm with a 572.... he works for it though....
I would say a higher revving large bore engine would be the way to go.... spread the power out...
Old 09-23-2019, 01:51 PM
Stan Weiss's Avatar
Stan Weiss Stan Weiss is online now
Bore 4.35" - Stroke 4.25" - ci 505.3
Bore 4.25" - Stroke 4.5" - ci 510.7
So you are talking about all of 5.4 more ci's
Bore 4.35" - Stroke 4.375" - ci 520.2
(4.35" - 4.25") / 2 = 0.05" So if I have the room by the exhaust valve I can run a 0.1" bigger intake valve.
Stan
Pontiac Pump Gas List
Old 09-23-2019, 03:20 PM
gman005's Avatar
gman005 gman005 is offline
I have a set of 4.350 pistons if you are interested.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 09-23-2019, 04:13 PM
Default combo
will be normally aspirated. May even be a pump gas combo before its over.
Old 09-23-2019, 05:13 PM
Thank you. Normally aspirated I would build the engine with the large bore. I have built both 4.250 stroke and 4.500 stroke versions. In a reasonably light car, I prefer the 4.250 stroke. 4.500 stroke puts allot of piston out of the bore and is hard on the skirts and piston rings. In a big power adder situation, I tend to go with a little smaller bore in a Pontiac as the potential for a larger intake valve is not as critical and the extra sealing area between bores is more of a factor under boost.
