Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 11-25-2023, 03:12 PM
BLACK70GTO's Avatar
BLACK70GTO BLACK70GTO is offline
Default WTB - 3.25” Main 4.25” Stroke Forged Crank
Anyone have a 3.25 main
4.25 stroke forged crank ???
Old 11-25-2023, 03:24 PM
Herb Hagan's Avatar
Herb Hagan Herb Hagan is offline
https://www.speedmaster79.com/PONTIA...00-RMS-2Pc-Ext
74 Ventura 462/#13 heads/3350#
10.38 @ 128.89 MPH, N/A, Stock suspension, 275/60 Radial, Street legal, Tagged & Insured
Old 11-25-2023, 03:25 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Are they on back order again?
Go fast, see Elvis!
Old 11-25-2023, 03:27 PM
Herb Hagan's Avatar
3" mains are out of stock
Old 11-25-2023, 04:29 PM
65madgoat's Avatar
3.25" are showing in stock and just what the original poster has requested.
Best he get on it.
The Following User Says Thank You to 65madgoat For This Useful Post:
Old 11-26-2023, 08:11 AM
chuckies76ta's Avatar
I have an RPM one. Straight shot oiling. Brand new in box. In Canada and there heavy as hell.
https://rpminternationalinc.com/cran...80-stroke.html
Old 11-26-2023, 12:08 PM
Mo's Avatar
Mo Mo is offline
What rod journal size? 2.20 or 2.25?
I have a SM 4.25 stroke 3.25 main with 2.20 rod ends. New in box, never used since the 455 block I got was cracked.
I’m about an hour drive away from you.
PM me if interested.
Systems under stress fail catastrophically
Old 11-26-2023, 05:24 PM
grivera's Avatar
grivera grivera is offline
Originally Posted by Herb Hagan View Post
The listing says 2.2 RJ but the specs say 2..25
I bought a 3” main 4.25 stroke from SM some years back and had to return it cause the RJs didn’t match the listing.
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
Old 03-17-2024, 05:03 PM
blackhawk6 blackhawk6 is offline
Sorry to hijack a slightly older thread but is this still up for grabs?
