Old 07-08-2023, 03:38 PM
Andre's Avatar
Andre Andre is offline
Default 1966 Gauge ground bracket
It's been a while, and I can't remember specifically to explain to my friend.
There is a metal ground bracket that attaches with 2 hex screws to the rear of the gauge cluster.
The other end attaches with a larger hex head screw to the pedal hangar assembly. I think the bracket accepts a aheet metal screw. I can't recollect if the bracket sits on top or below the hangar. Assembly pictures are vague. Its near impossible to see once installed or I'd look at my car.
Any help is appreciated
Old 07-08-2023, 05:34 PM
Peter Serio's Avatar
Peter Serio Peter Serio is offline
Default 1966 Pontiac A body cars the ground bracket
Is this the one your talking about?
Name:	65 vs 66 dash ground bracket for gauges_2.jpg
ID:	615587   Click image for larger version
Name:	66_GTO rally gauges_Ground bracket B.jpg
ID:	615588   Click image for larger version
Name:	66_GTO rally gauges_Ground bracket C.jpg
ID:	615589   Click image for larger version
Name:	66_GTO rally gauges_Ground bracket C3.jpg
Peter Serio
Owner, Precision Pontiac
Old 07-08-2023, 10:44 PM
Andre's Avatar
Yes. This helps tremendously
Old 07-09-2023, 12:26 PM
Default Ground bracket, = all 66 A body cars
That rear bracket is the ground for the gauges but also it is an anti-vibration device as the bezel in a 66 is much taller than the 64-65 bezel and so the center of the dash, it really needs a little bit of extra support.
NOTE: The far away (downward) end of the bracket rests in a slot on "top" of the brake pedal support. The screw that holds it tight threads in from underneath. (You will need to, at least, lower and/or remove the steering column tube to get into to space with a socket and an extension to tighten up that one bolt.)
Name:	66_GTO rally gauges_Ground bracket D2.jpg
Peter Serio
Old 07-10-2023, 07:54 AM
Andre's Avatar
I realized that. Gonna have to go backwards now
