#221
We(Joe and I) know the only issue with the pontiac head gasket to block is that large oil drain back so the sure fix is a Cometic with the smaller hole like the 301 head gasket has.If we think the water holes are a issue with the 301 gasket to head match we will just order the Cometic.Tom
#222
Ok,made the decision after looking at all gaskets to use the Butler gaskets.It looked to us that the oil drainbacks were a smidge smaller and "hope" they seal.The 301 gaskets hung into the CC too much for us.Here are pics of both on the head.Tom
#223
So Tom -
Does the rod shim spacers spin with the crank or are they keyed somehow to remain in a fixed position?
Follow the posts!Its a thrust bearing spacer between the block-cap and the inside of the bearing!Tom
#225
Bummer,on the back bumper again.Joe had a SBC had a rear cam bearing go bad on the dyno.Hope to have the heads on this week.Tom
#226
We're WAITING, Tom...........
“It takes considerable knowledge just to realize the extent of your own ignorance.” Dr. Thomas Sowell |
#227
Been 13 month!Dot you think im waiting?LOL
#228
Just jerking your chain, Tom.
#229
I know,nobody wants this done more than me(maybe Joe)He said he will try and have them on for me to see thur morning.Tom
#230
Heads are on,took my dyno headers to him.We need to get a Trandapt oil filter relocation kit.Getting a little closer.Took a pic with my Iphone and dont know how to post.Good news is the head gasket "looked" like it sealed.Joe is going to put the water to it before any oil goes in.Tom
#231
Good. I can't wait to see the dyno results.
#232
Joe is doing the clearance for the roller lifters on the pushrod cover,he has the oil filter relocation kit.I hope he gets the water to it next week to be sure it does not leak.I think the last thing to do will be order pushrods.Hope to have it on the pump soon.Tom
#234
Great news!Joe put the water to it today and it did not leak(so far).Still have the oilfilter relocation to over come with the headers.Push rods are ordered.Might be on the pump in a week or so.Tom
#235
Good luck! Can't wait to see what it does.
#236
Great news. Been watching and loving it since you started. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
#237
Oil filter no problem now.Just waiting for pushrods.Hope on the dyno next week.Tom
#238
ditto what Mark said. Le'Bone
#239
Well,if it was not for bad luck I would have no luck at all!Joe was setting the valves and something did not work!Looks like I gave him a RA V cam which has a diff valve placement on 4-6 and 3-5.Now we have to order a cam.CRAP!Tom
#240
LOL, you sure you're not related to me??? After building some Chevys, and a Buick I went back to building a Pontiac for a friend. I did the rookie backwards rod swap because of the opposite banks. Needless to say, I invested heavily in his engine, LOL. When other people mention that mistake I just drop my head and stay quiet.
Mark L
