From E-Heads to KRE High Ports
Hi all, first post here.
I've run my car on E-heads for years and from many of runs and methanol, the seats are just worn out. Excited to say my KRE High ports showed up last week. Jeff mentioned I'd need a longer push rod, so I'm wondering if anyone in here who made the switch knows exactly how much longer? I use the retro-fit Morels, Hydraulic roller. My old set-up used a 8.95" push rod and i actually had to use the Ford Windsor style rocker arms (harland sharp 1.6) for proper geometry on the E-heads. I would measure, but everything is at the machine shop and I'm just trying to get a head start on a correct push rod length. Thanks. |
I run crower 1.65 rockers and started with a 10.3 and had to go to a 10.4. Also had to use lash caps . That was with standard height hipo crower solid roller lifters as well.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
Just a little tid-bit to be aware of. Not related to pushrods. When you switch to the High Ports: Be aware that the timing cover to intake water crossover will no longer line up. It will be a mismatch of about 1/2". You will need to plug the passage in the intake or crossover and the timing cover. This is much easier to do with the parts off the engine. (Ask me how I know?)
The Following User Says Thank You to mgarblik For This Useful Post: | ||
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
Looking forward to seeing how these heads perform vs the edelbrocks. With my current combination, the fastest my 428 has been was 6.44 @ 105. The smaller chamber HP's and actually having the cam degree'd right and more flow, I'm hoping it'll go 6.30s in good air and 6.40's through the summer. |
http://www.krepower.com/Pontiac%20New%20Products.htm I know you can plug it but I just wanted it to work as intended. I think it looks better too. |
Eric
"Everybody has a plan until they get punched in the mouth" noted philosopher Mike Tyson Life begins at the end of your comfort zone. “The mind, once stretched by a new idea, never returns to its original dimensions.” |
Kauffman high port crossover came today. Nice quality casting. Machined angle fit the heads perfectly. The 2 mounting bolt holes required some slotting to line up correctly. O-ring fit/height was excellent. About 1/2 hour grinding and fitting and it's good to go. Nice piece for the $.
My pushrods ended up being 10.100". 10.3 or 10.4 makes sense if you have the taller valves for a roller cam. Eric
More often than not they are typically set up around 2.000" installed height.
And the valve diameter and stem length tends to be a bit heavy, keep that in mind with spring pressure to control the valves. Valves to consider: F1250P F1251P https://www.ferrea.com/pontiac-compe...ne-valves/p534 On my HP castings we used 2.230 titanium intake valves and 1.700 stainless valves, both 6.250" in length. The springs were Manley 221448 at about 2.100" installed height used in conjunction with a 50mm custom Bullet Racing Cams solid roller with 0.850" / 0.817" gross lift. .
mine took 10.3 with crower lifters
They KRE now have a water cross-over for the High port heads I believe. http://www.krepower.com/Pontiac%20Intakes.htm
keep us posted on your progress
i thought about a head swap and using these heads and was wondering the same on the pushrods you using shaft or stud rockers with the new setup? i think that has an effect on the length???? i was thinking these heads because of their 56cc offering |
I'll be used 1.6 or 1.65 harland sharps stud mounted. My cam is a 248/254 .563/.584 112 LSA Hydraulic roller. 428 block, should be around 13:1 compression now. I have a nitrous kit on it, but haven't ever sprayed it wide open. From the 330' on I've laid on it and it went 6.24 @ 113. Hoping to get my heads and engine back next week so I can put it all together , get the pushrods coming and take it out for a test n tune prior to the season starting. |
it's helpful was the time and mph with your current setup? you using a dome piston, and what CC and flow did you go with on the KRE? |
I dropped the long block in last night, probably a good 4 hours left to fire-up (put transmission in, button everything up, etc). Wish I could fire it tonight since its the nicest day we'll have until Wednesday, but spent too much time chasing my tail on some nitpicky things. I also ran into some snafu's with the heads. The water jacket holes were kind of burred and I guess the cheap tap I had wasn't cleaning the threads well and it boogered up one of the steel 3/4 NPT plugs, so that should be here today. I also ran into an issue where my Aerospace vacuum pump bracket doesnt line up with the holes on the heads (angle is right, but the two bolt holes are about .4" off length wise), so I'm going to have to think of a way to fabricate something for it to work. As close as the hole is to the remaining material of the bracket, it's going to be tricky.... and I'm probably overthinking it lol. Any picture or ideas you guys have would be appreciated. Ended up only needing a 9.35" push rod - interestingly enough the 0.4" the bolt holes are off on my bracket was the exact length my push rod needed to be longer... what are the odds lol. |
i'm very interested in what the changes did for you i seriously have an itching for the 56cc heads, and KRE said i wouldn't have piston/valve clearance issues. i wasn't sure cause i know eheads with stock pistons can/do what port flow did you go with and what intake you using? i may have missed some details so i'll recheck this thread |
I have run the 1.8" installed height springs with the E-Heads for years WITH A SFT CAM
and never had a valvetrain issue. Like that installed height spring. I run the PAC Valve Springs made by Peterson Spring in Three Rivers Michigan. My Uncles Pontiac Dealership was 1/4 mile from the Peterson Spring Engineering Center. Good choice Eric. Tom V.
"Engineers do stuff for reasons" Tom Vaught Despite small distractions, there are those who will go Forward, Learning, Sharing Knowledge, Doing what they can to help others move forward. Last edited by Tom Vaught; 01-25-2023 at 12:55 PM. |
hp heads
Check your rockers closely depending on your rocker style the 3/8 single taper pushrods will foul on the rocker near high lift requiring grinding for clearance. My combo was crower hippo solid rollers with 10.400 pushrods and scorpion rockers.
