What's a decent price for a 78-up Pontiac engine shaker asembly?
Looking at a complete 78 and up shaker assembly for the Pontiac motor. Would need to be restored but is complete. It is the version with round snorkel end.
What is a fair price? I checked eBay for reference and was surprised how high the asking prices were. Thanks
Michael Oshawa built 1 option Judge basket case. 463, SD KRE 295's, CNC'd factory intake, Cliff's Qjet, Stump Puller HR cam, RARE RA manifolds, Pypes exhaust, T56 Magnum, McLeod RXT clutch, 3.42 12 bolt. 24 year project almost done... |
PM sent.
The 78/79 air cleaner bases with the W72 snorkel or earlier 75/76 wide snorkels are worth more than the standard round ones, Ive sold a few of these recently for less than the ebay prices and even then they sold for $350+... on ebay or from the price gougers out there expect to pay $400-500+ for a nice one. The shakers are not as rare since they are the same for non W72 cars sell for about $200 or a little higher for a very nice one.
Thanks for the feedback.
I managed to pick this up tonight and made out better than I expected for $250 CAD (~$185 USD). Had been on Kijiji.ca near Montreal for a month and I happenned to be nearby for work so I made an offer and the seller accepted. Missing the air cleaner lid and a few minor cracks but just what I need for my drag car project. As I am new to F bodies, I have lots to learn . Is this the lower shaker or the later/taller one? Thanks
Looks like the lower rise shaker, like my 77 has...
Yes, I am pretty sure its the early 77 shaker. Smaller opening and pronounced ridge along the centre. Same one I have on my car. If you are not using the 2 port vacuum switch keep a hold of it AND the clip. I recently was on a wild goose chase looking for those 2 parts, they are not easy to find.
That is definitely the shorter 77 only shaker, looks to be in good shape though. |
The round snorkel is a better way to go, you do t need the plastic oval to round adapter. And the clips yo hold on are another hard one to find.
Yes the clips are hard to find, usually the shakers are missing the hose nipple and the ring. Also the one and 2 port clips on the bottom are hard to find. The one on the side Can be improvised out of a brake clip. Now look for the 4” hose. lol
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes pause pause F ire B irds 🇮🇱 |
If you open the Shaker it does not matter if you use the larger W72 oval inlet. Shoot a picture of where the ring attaches the metal base of the scoop to the air cleaner base. Some of the 77 short scoops used a 1/4" p[plastic spacer, and removing it gives another 1/4" clearance for any carb spacer or taller intake.
You can use some aluminum lawn chair screws top and bottom to attach scoop to metal or for my '64 Impala they have bolts to attach headlight bezel clips to the grill that are on top similar in appearance to the factory rivets. P DUd used to make a taller scoop you copuld bolt to the metal base. I think someone else is making them too now.
