RAM AIR V compression ??
lost again poo poo
factory block/crank/rods/heads all 400 diamond 4.155 comp height 1.720 eff.volume +13.5 ccdome int pocket 0.140 exh pocket 0.175 deck and milling head unknown ? gasket thickness to get about 11.1 ? john ricondas V thank you folks |
Here's the only answer that anyone can give you without YOU providing the rest of the needed details.
With a piston at TDC you need a total of 83.3 CCs to achieve a 11 to 1 compression ratio. The other thing that's certain is that 13.5 cc dome needs to go since I don't think you be wanting to grind / machine that 13.5 CCs into the chamber even if it could be done.
The Following User Says Thank You to steve25 For This Useful Post: | ||
Might give Rick Johnson in Crete IL a call and see if he remembers what the CR was.Custom Automotive.Make sure you have some time to give up when you call!Tom
The Following User Says Thank You to tom s For This Useful Post: | ||
thanks STEVE !!!
thank you steve your darn smarter than me
thank ya TOM
fishin must be good for memory
now i remember to have AMPLE phone time/that is a great man that helps us |
