69 Basket Case Bird - Need some help with Headlight Harness Routing
Questions for the team. Trying to figure out the correct routing of the healight harness and ground location on the basket case bird. That particular page on the manual is so faded I cannot tell exactly where things go. Here’s a couple of pix of the areas in question. Thanks in advance.
The forward light harness runs atop the passenger inner fender well and has I believe one or two push clips that slot into holes on the wheel house cover itself. The Grounds attach to the upper filler plate of the nose section. There should be notches there that the grounds come up through the bottom. They will be located about 4-5" inboard of the fenders.
Based on your pictures and the current status of front end construction, I would simply lay that harness out in its general location for now. When you get the driver wheel tub in place, you can run the harness there. When the front end goes on, you can complete the harness there.
Driver side, yeah fender well is the easy part.. Same as pas side for the grounds and it kind of looks like the push clip of the harness itself goes into the hole halfway up the extension sot he harness would go up and over the extension at that point? |
I highly recommend that you purchase a factory assembly manual for the 69 firebird. It has detailed images along with the part numbers.
1969 TA RAIII M40 Auto Cameo White/ Std Blue Int 1970 TA RAIII M21 4-spd Lucy Blue/Std Black Int 1971 TA 455 HO M22 4-Spd Lucy Blue/Deluxe White Int |
Yeah, here's the page showing the installation.
Finished?
69Nok, did you get your harness installed? Can we get a few pics of it completed as I am right where you were a few weeks ago. I have a digital copy of the Assembly Manual but pics are small and grainy so not much help. Thx. Dave
1970 T/A |
Thanks |
Thread Tools | |
Display Modes | |
