Old 04-20-2019, 01:37 PM
ejw's Avatar
ejw ejw is offline
Default initial setting for dbl adjustable rear shocks?
Swapping old rancho single adjust shocks for viking dbl adjust. Was looking for assistance in initial settings. I currently run rear shocks on 4. Car 3200lbs, 30x9 slick, PG transbrake 3000 launch, 1.36 60" w/ 4.10 rear. run coilovers w/ dbl adjustable in front.
Just looking for starting point to begin with. Thanks
Old 04-20-2019, 02:53 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
I would assume the factory sets them roughly in the middle on both settings.
I would just make a pass under full power and see what the car does.
Then adjust from there. If you need to adjust, do 2 clicks at a time.
Watch the 60 and 330. They will tell you if you are going in the right direction.
Also, make sure the slicks are set correctly. You should have little to no wrinkles when you launch.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
Old 04-20-2019, 03:44 PM
ejw's Avatar
ejw ejw is offline
Old 04-20-2019, 05:57 PM
mysticmissle's Avatar
I would set them toward the stiff side and make a series of increasing length passes until car has proven itself stable decelerating and accelerating. First time out with my Gto I nearlynwrappped it around a telephone pole because the shocks were full loose out of the box. When I let off from about 70 car went into severe wiggle. In addition to shocks being loose it had big Hoosier street tires that may have needed some
More air pressure. It was all new to me I got lucky. I suggest erring on the conservative side for a few passes
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 04-20-2019, 09:43 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
I'm running Viking, current settings. Basically their "starting point" for racing.
Front Shocks
RACE
12 compression
15 rebound
Towing
3 compression
3 rebound
Rear Shocks
RACE
8 compression
12 rebound
Towing
3 compression
0 rebound
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
Old 04-20-2019, 11:17 PM
Aaron Quinton's Avatar
Aaron Quinton Aaron Quinton is offline
I've not run Viking shocks. My AXO's have been ok so far. I have Santuff's on the list to change when I get some time. Check out Santuff's site, they have good information on where to set things up initially.
If you have a video of your car leaving I'd be happy to help with the initial set up. I'm sure Viking can help as well.
Old 04-21-2019, 12:57 PM
ejw's Avatar
ejw ejw is offline
Thanks guys for help. Just noticed last evening that the shock body hits the Calvert spring clamps bracket. Not sure if caltrac bars lower spring/shock mount plate is different from stock. I compared my old calvert Rancho springs and it’ seems to have a longer modified lower mount. I have an old set of shock extensions I can try if no solutions from calvert or Viking. I just want to check shock extension w and without adapter. Surprisingly Rancho shocks are 6lbs each and Vikings are only 3 lbs
Old 04-21-2019, 01:41 PM
ejw's Avatar
ejw ejw is offline
Here is pic of interference issue
