Old 05-27-2017, 11:39 AM
ejw's Avatar
ejw ejw is offline
Default prostar wheels and aftermarket front brakes
installed aerospace front brakes, work great, but need to use supplied spacer for wheel to clear caliper. Issue is the 1/2 studs supplied have 2" thread showing after spacer and prostar hub is 1.5" thick .
I've had these wheels for almost 20yrs. Is there a comparable rim out w/ a thinner hub. The prostar always seemed thick (street/strip rim).
thanks
Old 05-27-2017, 04:54 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
thanks
Welds RT-S series wheel was designed for more caliper clearance....
http://weldwheels.com/shop/street-st...71-wheels.html
Hope that helps
Not sure of your location but give Larry a hollar. Good guy and easy to work with.
https://www.larryhodgeracing.com
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23
Old 05-27-2017, 05:14 PM
ejw's Avatar
ejw ejw is offline
Thanks, I'll look into it
Old 05-27-2017, 08:58 PM
ejw's Avatar
ejw ejw is offline
S/st do you have an idea on backspacing. Offer 2.5 and 1.5. For 2nd gen. Car sits low was thinking 2.5 to tuck tire in a little too keep away from fender lip as car settles on launch.
Old 05-28-2017, 11:06 AM
Skip Fix's Avatar
Skip Fix Skip Fix is offline
My Prostars clear my Wilwoods on the Camaro/IA project.
Skip Fix
Old 05-29-2017, 11:21 AM
S/st 54's Avatar
I think they offer 2 diff back spacing for the the 15x4's I agree with you the more back space on the fronts to tuck the tire/wheel combo inside the looks good and serves better purpose for when the car "settles"
Either way I think those wheels look good no matter the back space....... Like I said if ya get a chance give Larry a hollar heck of a good guy!!!
Old 05-30-2017, 07:48 AM
BDHABT's Avatar
BDHABT BDHABT is offline
When I bought my Alumastars,I went with the 2.5" backspace.
Looks good,and does`nt hit anything.
`70 Firebird,Original Owner car
Ken French Built Chassis
Carlquist Competition Engines IA2 505
Competition CNC Ported Super Chiefs
CCE Ported Gustram
Twin Dominators from Shaker 455
963 HP
`09 Electra Glide Standard.
`03 F-350 7.3 6-speed 4x4 Crew Cab Dually.
