Tail light circuit
My tail light circuit is giving me fits. I can't get power feeding them at all. I have 3 different light switches and none of them feed power to the tail light, dark green wire. I pulled one of the switches apart and it looks like the sliding contact from the tail lights only connects to the rheostat feed. Headlight circuit works fine. The only power supplied to my switch is the tan wire. Does anyone know how the switch connects power from connection 1 on the switch to connection 5? Or am I missing another way that power feeds the tail light circuit?
Thanks,
Tom 1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121 1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125 Last edited by Tom63LeMans; 03-26-2017 at 09:21 AM. |
Figured out my problem. Found a correct switch that has a bridge from 1 to 4.
Tom 1963 Lemans -428 +.030, SD Perf KRE heads, turbo 350, 9" Ford 3:90, 11.01@121 1956 Chieftain gasser, 461 stroked 400, SD Perf ported E-heads, turbo 400, Dana 3:70 10.40@125 |
details?
Does this detail show in the 1963 wiring diagram?
Although the 63 & 64 to 67 look alike, 63 has an unique switch output!
Attached is the differences in the two switches. John |
Doug, the jumper is not shown in the schematic. I guess it was 3 64-67 switches I was trying. As soon as I found the 63 switch in my junk bin it all made sense. It was in bad shape but was able to use parts from 3 switches to make one good one. They are odd little cars for sure.
How in the world are you doing Tom?? Long time buddy!
Mike McCarty You can drop the line, but you'll never kill the spirit! Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far |
Hi Mike, yes it has been a long time. Hope all is well with you. I'm doing great and working diligently to finally have the car at Norwalk this year. Hope to see you there!
Likewise buddy! Get her done.
