tach testing
I have 3 62-64 full size tachs. Is there any way to check them besides on a running motor?
Mike McCarty You can drop the line, but you'll never kill the spirit! Pump gas 535 w/Marcella cv/1's. 11.0 compression, 4000 stall, 3.73 gears, 275 radial, to the axle exhaust, 3470# w/driver. 9.49 @ 140..........so far |
Yes.
The tach will need [a] 12v + supply to it & [b] hooked up to the coil -ve terminal. |
Hello
I would go to a speedometer shop ... and have them checked for accuracy ..
I have a couple nos hood tachs .... 1 reads perfect to 5000 then every 1000 loses 400 rpm .... 1 reads fine to 3000 then falls on its face another works fine thru the rpm but is off by 700 after 1500 or hook up a good quality tach along side yours on your buddys old car and compare em best at the shop .... they should be able to give you a read out every 500 rpm on each Scott is this guy close to you ? https://www.bobsspeedometer.com/1/120/index.asp |
Post #2 is connected to a running engine. Sorry if that was unclear.
The tach will probably have a ground connection/terminal if it has a plastic case.
If the case is metal, the case should be grounded. |
Find a friend with an audio generator with square wave output option. Add a single-transistor NPN amplifier stage having its output zener regulated to 12 volts. Use this 12v square wave to bench-test the tachometer. Just do the math for what frequency to use for a given RPM. [Example: a V8 at 6,000 RPM would be a 400 Hz signal]
Thank you all for the replies.
