Old 01-03-2022, 01:11 PM
beertracker's Avatar
beertracker beertracker is offline
Smile Where to buy steering rag joint for 70 LeMans?
I hope this is the right group to post in. Where to buy a steering rag joint for a 70 LeMans?
Old 01-03-2022, 01:53 PM
1968GTO421's Avatar
I usually get this from Ames:
https://secure.amesperf.com/qilan/Se...E7B990889529A1
but may places lke NAPA, Rock Auto should have them
GTOAA--https://www.gtoaa.org/
Old 01-06-2022, 11:21 AM
Can you replace the rubber fiber part only or do you have to buy the complete assembly? I am concerned about the safety of rubber fiber part since it's original with my car.
https://www.summitracing.com/parts/c...+5ba1510bccac7
Old 01-06-2022, 12:48 PM
Sirrotica's Avatar
Most of the rubber portions are made from sidewalls of tires, so as as per tire manufacturers recommendations, should they be replaced every 10 years ?.........
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 01-06-2022, 03:45 PM
Tim john Tim john is offline
DSE (Detroit Speed and Engineering) also offers them. I have one. Very high quality, not a cheap China knockoff. You can also check with Borgenson, they make them as well. Not sure who actually makes the DSE units, could be Borgenson but I do not know.
On my 69 Firebird convertible I actually removed the rag joint all together and installed a stainless steel U-joint (Borgenson) and cut a stainless double D shaft to make up the difference in length so the steering is very responsive, absolutely no sloppiness or flex that a rag joint gives. DSE offers this as well but did not have what I needed back then so I made my own like for like. My original steering gear box is also (now) quick ratio at 2-1/4 turns lock to lock (Built by "Turn One" in Saginaw, Michigan).
Tim john---
Old 01-06-2022, 05:29 PM
sdbob sdbob is offline
Looking at the joint. I often wondered if conveyor belting would work(make your own). I might have asked this yrs ago. Cant remember the responses.
Old 01-06-2022, 07:25 PM
Tim Corcoran's Avatar
I'm running a 57 year old OEM unit seems to work fine. Never heard of one failing
Tim Corcoran
Old 01-06-2022, 09:24 PM
Well this answer adds zero info to my question of post #3. The reason I asked my question here is this suppposed the best source of pontiac info on the internet.
Old 01-06-2022, 09:32 PM
Sirrotica's Avatar
Took me less than a minute to find the answer:
https://www.autozone.com/suspension-...B&gclsrc=aw.ds
https://www.napaonline.com/en/p/NOE6...-0-gaNycGzNEH0
My post #4 was an attempt at humor, obviously you didn't recognize it as such.
A quick search on PY has 2 results from the past;
http://forums.maxperformanceinc.com/...d.php?t=843693
https://forums.maxperformanceinc.com...67#post6175367
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 01-06-2022, 10:32 PM
I spent a lot of time searching online for the keyword "rag joint." Obviously I was using the wrong key words, Steering Coupling Disc Kit was the right combination to use. I didn't expect a hyperlink; a simple yes or no to post 3 is all I expected.. Thank you for going above and beyond. Sorry I am not as knowledgeable in proper steering component terminology as all of you are.
Old 01-06-2022, 11:12 PM
Sirrotica's Avatar
FWIW, I searched rag joint replacement, not steering coupler.
Here's my google search:
https://www.google.com/search?q=rag+...hrome&ie=UTF-8
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
