Old 09-20-2019, 09:33 PM
68ragtop's Avatar
68ragtop 68ragtop is offline
Default a better Glue than 3M spray adhesive?
Anybody every use a contact adhesive that bonds as good or maybe better than 3M spray? I have been using 3M stuff for years & it generally works fairly well, but I Want to bond something where I need a little more working time & would also like to brush it on from a can so I don't; have to mask everything off. Anything better out there? Maybe a type of flooring adhesive?
68 GTO 4-spd Convertible
78 S/E Trans am L78, WS6 Auto
78 S/E Trans am W72, WS6 Auto
79 10th aniv W72 Trans am
80 Indy pace car Trans am
89 Trans am GTA
Old 09-20-2019, 09:56 PM
Stuart's Avatar
Stuart Stuart is offline
3M makes a high performance brush on contact adhesive. https://www.amazon.com/3M-Neoprene-P.../dp/B000WXL202
The Following User Says Thank You to Stuart For This Useful Post:
Old 09-20-2019, 10:57 PM
400 4spd.'s Avatar
DAP Weldwood Cement is what I use if I don't plan to take it apart again. MUCH better adhesion than any 3M product I've used.
Old 09-20-2019, 10:58 PM
Rocco Testa's Avatar
Rocco Testa Rocco Testa is offline
Formica Glue also works. You can buy it in a can. I think the working time is the same. You can also just apply to one side
Old 09-21-2019, 06:34 AM
dhutton dhutton is offline
DAP Landau adhesive
https://www.ebay.com/itm/DAP-Weldwoo...ry!76233!US!-1
Don
Old 09-21-2019, 07:01 AM
68ragtop's Avatar
Thanks for all the ideas! I will read up on all of them
89 Trans am GTA
Old 11-02-2022, 11:11 AM
beertracker's Avatar
beertracker beertracker is offline
Dap Weldwood Cement has high heat resistance. I plan to use it to glue a fabric cover on top of my rear gift tray. I think it would be perfect for this application since the gift tray is exposed to the hot summer sun.
Old 11-02-2022, 12:16 PM
rohrt rohrt is offline
Dap Weldwood Cement is the best.
Its what you want to use if doing headliner or convertible top. In my case I used it to recover my dash on my 64.
Old 11-02-2022, 01:19 PM
dataway's Avatar
dataway dataway is offline
Another vote for the DAP ... when it's stuck ... it's stuck.
