Old 01-16-2023, 06:56 PM
A.W.Dille A.W.Dille is offline
Default New engine
I'm into a 72 Grand Prix with a freshly built 71 455. Intake was leaking at the exhaust crossover. Pulled the intake to replace the gaskets and get it sitting correctly. Only one bolt torqued. The man that built the engine has since retired and was a professional engine builder. I can't believe that he missed the cracks in this head, casting 66. Owner dropped off a pair of 96's this morning that I'm going to have rebuilt to go on the 456.
I've gotten used to go behind other shops work to correct things.
ID:	605334   Click image for larger version
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear
85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book.
87 F350 6.9 4 speed dually
A poor man has poor ways.
Old 01-16-2023, 07:03 PM
What you’re seeing is normal, it’s simply the parting line where the two halves of the mold come together. It’s quite common actually.
Those are not cracks, your heads don’t need to be replaced. Just use a small dab of ultra grey sealer to prevent oil from migrating into the intake ports.
The Following 3 Users Say Thank You to b-man For This Useful Post:
Old 01-16-2023, 07:13 PM
That one runs clear to the pushrod tube. One port (I tried to get it in the picture) had been welded. The other head is perfect.
Old 01-16-2023, 07:14 PM
No matter what the 96 heads will wake up that 455 with a nice 1-point bump in compression.
Old 01-16-2023, 07:22 PM
I have seen many Pontiac heads with cracks in this location. Most are superficial, easily repaired with a bit of epoxy.
Dr. Thomas Sowell
Old 01-16-2023, 07:58 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Probably one of the few practical uses for JB Weld.
Go fast, see Elvis!
