#81
Only when you throw Steve C kind of money at him.... Otherwise he rolls his eyes and says he's to busy
#82
FWIW I don't believe those are original "Ultradyne" lobes.... Ultradyne goes from .426 lobe to .434 in their Master Cam Catalog. I doubt Harold came up with a new family of lobes since my catalog considering the state his business was in. Generally I feel anything up to a .440 lobe is reasonably safe to use in a factory block with a lifter bore brace..... I wouldn't worry about running that cam. We used a 268/272 .420 lobe on a 110 and made 735 on a pump gas Hi-port factory block combination...... The springs were on the heavy side and the guy has had zero issues. |
The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
#83
Somewhere about it was stated Bullet lobes. Intake - Bullet-R299-4315 Exhaust - Bullet-R308-4315 Stan
#84
Wasn't sure if that meant "Bullet" or "Bullet Ultradyne". |
#85
Those are Bullet Racing lobes, not UltraDyne.
( Paul.... I bought the HP raw castings and John paid Rick for the port work .... and it was back when I worked for a living ) .
#86
JM posted those numbers here himself. You question that guy ? All his stuff is about as good as it gets. Intakes, E heads, Pro Ports, Tigers, High Ports and all done in pure aluminum. IMO, the best. And that is not saying there are not others just as good. |
#89
#90
Yes, I should add is that my graph is in crank degree and and this changes the x and y axis scale. Programs like Cam DR and Audie Cam Pro Plus show these graph in cam degrees. Stan
#91
A couple pages of pointless chest beating and insults by the usual suspects has been deleted. Carry on.
#92
Since Jakes cam card was post.
I believe this is a dyno sheet from Jake's 434. While I would have liked some other information on the dyno sheet, I did like that they showed cranking compression psi Stan
#93
It really holds onto the power
#94
It sure does. Looking at that it looks like I would want to shift that close to 8000 RPM.
This Jake's top end. Ceralli Edelbrock 65cc "Tiger Cub" cnc ported standard port 348 cfm @ .800 lift 2.15/1.71 Manley Gen II stainless valves. 11.33:1 comp. PAC 1325 springs titanium retainers & locks from Scott Brown Yella Terra 1.65 shaft rockers from Butler Calvin Hill's solid roller lifters with bushings Trend 3/8" .135 wall pushrods from Scott Brown Mega brace installed Scott Brown roller cam. .769/.767 lift. 4500 Victor ported by Johnny at Ceralli's. Mark Whitener built 1050 4500 Stan
#95
My heads are close enough to those E heads. Flow more with a bigger valve. 434 vs a 461. 11.33-1 CR vs 11.5 Ported ring pack that has been back cut Crower 1.7 shafts vs YT 1.65s Splayed caps with filled block and Mega Brace. Trend 3/8 pushrods from KRE Steffs pan with kickout and double teflon scrapper Moroso 3 vaneVictor Performance Carb built 1050 His engine does have a lot more lift on the cam. I am too chicken to try a stick like that. I would be happy with 705 HP I am sure his was put together by a pro. |
#97
I believe Jake and his dad built it
#98
Humm, the pulls done at 100 rpm increments, usually not the norm. Peak torque around 5700 rpms and peak hp around 6900 rpms. 1/2 pump gas 1/2 race gas. Total timing 39.5 degrees thats allot of timing. Water average 149 degrees. Although not many make 1/4 mile run at 150 degree water. AFR not to bad. I’m just wondering how many runs it made down track, what vehicle verified weight was. I’ve always used 8-10% drive tran lost trying to figure real hp once its in the car and going down track.
Does anyone know what it ET and mph and weight…was. how many runs once every thing was sorted out. Were runs made on pump gas or race gas. What it ended up needing for stall convertor and gear. All that would help on reading dyno numbers. Reading the average numbers posted on dyno sheet and figure drive tran lost kid of puts it altogether. So in vehicle figuring drive tran lost probably around 650 hp. Also wondering what shift points where. 7000-7500. |
#99
Between printed and actually files from super flow dynos I have a don't know how many 100's of dyno pulls. Almost everyone one of them is in 100 RPM increments. Stan
#100
Have quite few myself, guess it is the norm. Either way shouldn’t effect dyno numbers. Really wasn’t my point.
