Old 05-13-2023, 11:01 AM
65madgoat's Avatar
What is everyone's take on this video and results/documentation from it:
https://www.youtube.com/watch?v=v_qUY4E33r0
  #42
Old 05-13-2023, 11:04 AM
Formulas Formulas is offline
Originally Posted by chuckies76ta View Post
Ok, I like that idea of moving the coolant above the thermostat.But where is your supply coolant coming from? By pass, heater hose return or both?
The entire OE system is functioning PLUS the addition of 2 -6an constantly pulling from back of engine
some may say -6 is small... its an addition not a main system in fact with this same architecture using say 2 -12an or maybe 2 -10an lines the thermostat might not open to often unless running the engine hard
this is intended for street strip fair weather no heater core, after very stable temps and iam quite sure i will get them
The Following User Says Thank You to Formulas For This Useful Post:
  #43
Old 05-13-2023, 03:41 PM
Gach's Avatar
Gach Gach is offline
Thats just about my same system, I used 2-10 an, like I said I tired the thermostat deal, tired it with drilling holes. The biggest problem I had was cruising around, and getting stuck in traffic. Thing would go to 220 degrees. It seem ok at first. Tired different thermostats but nothing changed. But once I went to the resticker never had a issue in traffic again. But hey you don’t know until you try it I guess. I also run 15 lb radiator cap. I just think having that Constant circulation from front of the heads as well as coming from the back of the heads makes the difference, I don’t know but thinking coming from the front of the heads and relying on thermostat to open or two small holes might have something to do with it. Not to say running thermostat won’t work for others you never know until you try it.
Old 05-13-2023, 03:47 PM
Gach's Avatar
My main concern was the reliability of the thermostat, if your stuck out on a Cruz and it screws up, then what do you do. For me away running the restrictor its not going to happen. The other thought is that thermostat being in there year over year, no telling when or if its going to screw up and not open. Just something to think about we put these cars away year after year then forget about thermostats because last time we took it out every was fine.
Old 05-13-2023, 05:31 PM
Gach's Avatar
thermostats have been in billions of cars since when??? and your scared !!
Sure they have, but whats the quality of the ones available lately. Not saying their all bad quality wise, but only what’s available local parts stores. I’m not telling anyone not to run one. Just piece of mine for me not having to run one.
Speaking of dreams I had this real weird dream the other night, I dreamt I swallowed a 2 pound marshmallow, when I woke up my pillow was gone.
