Old 03-31-2023, 09:23 PM
tom s tom s is offline
FYI,Tom makes and is in his catalog a pontiac 6.625 length,980 pontiac pin with a BBC big end.They allow you to use a aftermarket crank and use a off the shelf pontiac piston.Tom
The Following 4 Users Say Thank You to tom s For This Useful Post:
  #62
Old 03-31-2023, 10:02 PM
TransAm 474's Avatar
TransAm 474 TransAm 474 is offline
Thanks for clarifying that Tom, I never even noticed that until you mentioned it ....
1978 Trans Am
Pump Gas 461 Stroker
  #63
Old 03-31-2023, 10:35 PM
Lou,they are in the catalog!I talked to him a couple weeks ago.He had them in stock and did not realize they were in the catalog.Search for your self.Tom
The Following User Says Thank You to tom s For This Useful Post:
  #64
Old 03-31-2023, 10:39 PM
Molnar
  #65
Old 03-31-2023, 10:41 PM
For NON believers!
  #66
Gach's Avatar
Gach Gach is offline
Just went to his website dose not list them under Pontiac rod. So why would they be in his catalog and not on his website. Plus like I said that’s not what he told me today. No big deal
Old 03-31-2023, 10:47 PM
Gach's Avatar
For NON believers!
Tomas you better read it closely listed as 2375 BBC is 2.225.
Old 03-31-2023, 11:12 PM
BBC rod J is 2.200
  #69
Old 03-31-2023, 11:43 PM
Gach's Avatar
BBC rod J is 2.200
Exactly 2.200 not 2.375 that listed in your catalog shot
Old 04-01-2023, 12:02 AM
Gach, if you look at the picture Tom posted, you will see there is indeed a Pontiac rod listed with a 2.325" Big End as well, along with the standard Pontiac 2.375". These specs are what the rod BORE measures(without the bearing installed), that spec is not what crankshaft journal(crank pin)they fit. A 2.325" bore is indeed the standard BBC size, it fits a 2.200" Crank Pin with the bearing installed. The Standard Pontiac rod uses the bigger 2.375" Bore, which fits the standard Pontiac 2.250"(2.249") crank pin with the bearing installed....
1978 Trans Am
The Following 2 Users Say Thank You to TransAm 474 For This Useful Post:
  #71
Old 04-01-2023, 12:18 AM
Gach's Avatar
Ok gotcha wasn’t figuring for bearing thickness I apologize Tomas you are correct. Still Molnar said those Pontiac rods listed aren’t power adder rods. Great that he offers tho.
The Following User Says Thank You to Gach For This Useful Post:
  #72
Old 04-01-2023, 12:41 AM
No problem Gach, and you are correct, they are not offered in the Power Adder version, nor are they available for a .927" pin like you need, atleast without special ordering the with the smaller bushings like you mentioned earlier, but you still wouldn't have the beefier Power Adder rod when it's all said and done. I don't blame you for not wanting to go that route on this particular combination that you are working on at the moment. I would pay the little extra and buy the BME rods that correctly fit the combination for this build.
1978 Trans Am
The Following User Says Thank You to TransAm 474 For This Useful Post:
  #73
Old 04-01-2023, 01:48 AM
Dragncar Dragncar is offline
Neither have I their new kid on block. Jury still out. There’s a lot of information in this thread the readers will decide for themselves.
Might want to explain this one.
Is it a out and out lie, or did you just make a mistake ?
Molnar rods broke in half and windowed the block, you say.
And not only say you have not heard anything bad about them, but forgot this post.
I did not.
Name:	Screenshot 2023-03-31 at 20-57-27 The IMPORTance of what you buy - PONTIAC ZONE TECH FORUMS.jpg
ID:	609996   Click image for larger version
Name:	Screenshot 2023-03-31 at 21-03-19 The IMPORTance of what you buy - Page 2 - PONTIAC ZONE TECH FO.jpg
  #74
Old 04-01-2023, 09:14 AM
slowbird's Avatar
slowbird slowbird is offline
Good for you
Thanks Gachy, you acknowledgement is much appreciated
  #75
Old 04-01-2023, 09:21 AM
Half-Inch Stud's Avatar
I think you can economically bush down from .980 to .972
Wondering if sbc 400 slugs are still the real weight reduction improvement. Since i had forged TRW sbc400 slugs and they were extremely light compared to Any PMD slug.
  #76
Old 04-01-2023, 12:25 PM
PAUL K's Avatar
PAUL K PAUL K is offline
I did not.
That is funny chit!
Lots of Mommaluke's out there.
Go fast, see Elvis!
  #77
Old 04-01-2023, 12:37 PM
Bushing a rod from .980 to .927 isn’t really an
issue. You MIGHT have to hone out the small end a tad if the bushing OD’s are different.
Dr. Thomas Sowell
  #78
Old 04-01-2023, 12:58 PM
Gach's Avatar
I did not.
That was part of my Conversation with Tom the other day and he explain why it happen, so why do you want to drag him though the mud.
Old 04-01-2023, 01:02 PM
Gach's Avatar
Tom said he could do it re-bush rods..it would cost $200.00 more for the rods
  #80
Old 04-01-2023, 01:10 PM
Anywayz....i thought the GRP rods were the ECM choice for rods.
@Lou, hey ya just can't shake a stick them Molnar cranks though, huh.
