64 gto wire harness Bracket
on a 64 GTO which valve cover does the engine wire harness follow? I'm installing my valve covers this weekend and need to know which side the wire loom bracket gets attached to. Or should there be one on both sides?
Thank you! |
On my 64 LeMans the bracket was on the passenger side.
Sent from my XT1080 using Tapatalk
I don't always cross thread the bolt - but when I do I run that bitch in with an impact until it's tight! |
Driver side for the alternator wires.
Practicing social distancing for 65+ years |
Wire loom is on RH side. Alternator wires travel across the front of intake.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
thank you!
