Old 07-01-2018, 03:03 PM
remy30006 remy30006 is offline
Default 64 oil pressure sender and ignition coil?
Two questions it seems that when looking for an oil pressure sending unit its 65 and up. does 64 have a different sender? was it long or short?
Also is there a good source for a 64 ignition coil that fits in the stock bracket? I have what I believe to be the original bracket but went to napa and the new coil has a bigger diameter and wont fit the bracket.
Thank you!
