Just want to post this in the 64-65 section. I contacted Scott Tiemann and ordered the "Dash Dial Blue" lacquer paint that he had specially formulated. He also informed me that I called just in time as PPG was ending the sale of lacquer in Michigan. He told me the minimum mix is 1 pint. This will make 4 spray cans. So I didn't want to waste any of the pint, I bought all 4 cans. I plan on using one. Another board member plans on buying 1 from me. That leaves 2 left. If anyone is interested, please PM me.
Tony |
PM sent
PM sent.
That picture of your dash and the radio is the exact blue I am looking for for the interior of mine. You don’t happen to have a paint code or know where I can find it do you
The 4 cans of paint have been sold.
Tony |
Update: 2 Forum members who each bought a can of the paint said it doesn't "look right". Back to the drawing board.
could you post the code paint code that Pete uses? Thank you |
remy,
In my pile of 64 GTO documentation...will dig it out and let you know......MJS |
PPG Lacquer Duracryl
1pt. mix DMA349 - Fine Alum. 206.9 DMA358 - Black 155.9 DMA375 - Blue 10.4 DMA342 - Blue 54.1 DMA360 - Dark Red 9.8 Med wet final coat after coverage.
Thanks Pete, you saved me some work, LOL
Please let us know how it works out
Pontiac Dash Color.
I have had to use several different brands of paint therefor mix formulas over the years. If I recall the mixture above should yield the color shown below. That or very close to it. If it does or does not, please post the results.
If not I will search thru my old files and folders, perhaps I have another. Some of the mixes from years past I had mixed by eye and some of the resulting paint had to be ever so slightly "tinted to match" at the body shop's. (Paint store.) That was a long time ago. Unfortunately that mix was never written down. It doesn't matter anyway. That store changed paint suppliers shortly afterwards and when I went back to get some more, the guy that mixed it for me was no longer there.
Pete, that looks pretty dang good to this untrained eye!
Tony |
Very important: the color primer you set that paint on top of will affect the look of the color.
I like to use light grey or medium grey or bare steel. Just FYI. Dark grey or red oxide primers under that color are likely to give you an undesirable result. I can not say what that color will look like if sprayed directly over top of chrome. I think GM did but they had experts in all kinds of stuff and I am sure the mix they used even had some kind of a binder in it to be able to put the color directly on top of bright chrome without any issues. Personally I would use a light coat of "etch" primer just to give the color some extra grip. A nice primer I have had good results with in the past is sold by TP Tools in Canfield Ohio. www.tptools.com Their part # 5915 Quick Etch = one 12.5 oz. spray can. It comes in a light shade of zinc chromate green; as a happy accident this color is a very good base-tone under the green/ blue/ gray color everybody is looking to match.
Peter Serio Owner, Precision Pontiac Last edited by Peter Serio; 05-19-2018 at 07:23 PM. Reason: spelling fix. |
Pete,
Thank you so much for the code. this has been very expensive and frustrating to this point trying to find something close to match original parts |
