Old 01-05-2018, 08:46 AM
remy30006 remy30006 is offline
Default rag joint restoration
I have a very nice original rag joint but I'm having an issue getting continuity through the ground wire. the wire is good but I seem to have a bad connection where the wire is pressed under the plate. is there anyway to take them apart to clean the connection? or is there any other way to fix it?
Thank you!
