Old 12-29-2017, 12:29 PM
remy30006 remy30006 is offline
Default fuel filter help please
would anybody be able to help with a parts breakdown of the fuel filter and related for a 64 gto non ac 4 barrel?
Thank you!
Old 12-29-2017, 01:00 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
This is the fuel filter used on a OEM AFB carb without AC.
You can readially purchased these most anywhere.
Another number I found is #3759764 (STRAINER, fuel inlet).
Chris.
ID:	471184   Click image for larger version
Old 12-29-2017, 01:02 PM
Old Goat 67's Avatar
There was also one in the gas tank.
Old 12-29-2017, 01:34 PM
carbking's Avatar
carbking carbking is offline
The 7013404 filters come in the better carb rebuilding kits.
Jon
Old 12-29-2017, 03:49 PM
I'm sorry, I was looking for the canister filter and bracketry break down assuming there was an inline filter bolted to the timing cover on the 4 barrel non AC cars
Thank you!
Old 12-29-2017, 04:19 PM
60sstuff's Avatar
They never used the metal canister fuel filter on a 64,65,66 GTO AFB.
You could easily add one.
Old 12-29-2017, 04:46 PM
Cardo's Avatar
Cardo Cardo is offline
The AFB with A/C cars all got the canister. The return line to the tank comes off of the fuel filter.
"I know just enough to keep me here, but not enough to get me out"
Old 12-31-2017, 09:49 AM
So if they didn't get the canister did they just have a hose all the way from the fuel pump to the carb tube? Was there a bracket to hold the hose in place?
Old 12-31-2017, 01:11 PM
Tom Vaught's Avatar
Boost Engineer
THE RUBBER HOSE WENT FROM THE FUEL PUMP TO THE FRONT OF THE VALVE COVER THEN THE STEEL LINE #21 (IN PIC #2) CONNECTED TO THE RUBBER HOSE AND THE STEEL LINE HOOKED INTO THE AFB CARB'S FUEL INLET FITTING.
TOM V.
Old 12-31-2017, 01:54 PM
TOM V.
Tom,
Did you attach pictures? What are you referencing?
Thank you for the help
Old 12-31-2017, 02:36 PM
indymanjoe's Avatar
The Picture in post 2
Old 12-31-2017, 10:56 PM
60sstuff's Avatar
This is how the factory ran the fuel line from fuel pump to the AFB on a non-air conditioned 65.
Rubber fuel hose, then an Aluminum line, not steel!
Chris
ID:	471354   Click image for larger version
ID:	471355   Click image for larger version
ID:	471356   Click image for larger version
