70 Drum Brakes
1. Is there any way to convert my front drum brakes (70 GTO Judge) to manual disc brakes and keep my "drum" Rally 11 rims?
2. If the conversion is not possible without changing the rims (which I will not do) can someone recommend a set a good brakes pads for the drum brakes? Much appreciated!
Buy a GOAT....they eat anything! |
Here is a web site I ran across. Haven't used them myself. they sound like they might be what you're looking for. http://www.musclecarbrakes.com/
Quite certain that ALL rally IIs are disk
"At no time did we exceed 175 mph.” Dan Gurney's truthful response to his and Brock Yate's winning of the first ever Cannonball Baker Sea-to-Shining Sea... Still have my 1st Firebird 7th Firebird 57 Starchief |
Yes absolutely any 68-72 a body brake parts are a direct swap. I have found the CPP kit to be the best with a lifetime warranty for none wear items
[QUOTE=tempest1964;5788661]Here is a web site I ran across. Haven't used them myself. they sound like they might be what you're looking for. http://www.musclecarbrakes.com/[/QUOT
I have these on all four corners without a power booster and they are as good as advertised. The stopping power is at least as good as a stock disc brake system and I haven't been able to fade them yet, even at 120+ on the top end of the drag strip. I tried all of the top tier shoes (Raybestos,Wagner,etc) and honestly they all sucked. I was ready to convert to discs but tried the Musclecar Brakes stuff and decided to keep them. Just swapped the shoes on with new parts store drums and hardware, not the Cryo drums and hardware MC Brakes sells.
68 GTO,3860# Stock Original 400/M-20 Muncie,3.55’s 13.86 @ 100 Old combo: 462 10.75 CR,,SD 330CFM Round Port E's,Old Faithful cam,Jim Hand Continental,3.42's. 1968 Pontiac GTO : 11.114 @ 120.130 MPH New combo: 517 MR-1,10.8 CR,SD 350CFM E's,QFT 950/Northwind,246/252 HR,9.5” 4000 stall,3.42's 636HP/654TQ 1.452 10.603 @ 125.09 http://www.dragtimes.com/Pontiac-GTO...lip-31594.html |
Have also installed the special Matrix shoes & spring kits on a pair of early GTO's. Owners were VERY happy with the new found Whoa! Bought both sets when the company was Praise Dyno Brakes before the name change (same company). Have since bought special matrix shoe & spring sets for my '71 233's. Both are manual drum cars & besides the Musclecarbrakes.com shoes are being assembled with low mile original front drums that I had cryo'ed locally.
Good feedback....thanks guys!!
I just purchased the full kit from MCB (cyro drums as well). The kit appears to very good quality & everything is packaged & labeled very well. I'll report back in the spring when the car hits the road.
