Old 09-23-2022, 12:36 PM
GoatRider's Avatar
GoatRider GoatRider is offline
Default Short block machine work in Arizona?
I have been out of action for over 10 years, but would finally like to have my block worked on and rotating assembly balanced. Well it seems like all the Pontiac specialist machine shops that I knew of in the Phoenix area are gone, and so is AZ Crankshaft and a certain forum member both in Tucson are also out of business?
What is my closest option worth sending a good 400 block and 15 yr old Scat crank to for a mild blower build ~ 700hp?
"Nothing Beats an Ol' Goat."
Old 09-23-2022, 01:02 PM
Steve C. Steve C. is offline
Paul Carter has built numerous Pontiac engines and has in the past posted here on PY.
Unless things have recently changed Paul operates Carter Cryogenics in association with Koerner Engineering in Tucson Arizona , they build racing engines.
Old information here:
Old 09-23-2022, 01:07 PM
Dragncar Dragncar is offline
Paul is still in business. Busy from what I hear.
Old 09-23-2022, 07:26 PM
The last time I talked to Paul he had a two year waiting list.
Dr. Thomas Sowell
Old 09-24-2022, 10:33 AM
Frank from all Pontiac is in that area. I'm sure he knows where to get some machine work done around there
Old 10-09-2022, 07:18 PM
Steve Barcak's Avatar
I have most of my machine work done in Chandler at CBA. Talk to Scott or Zack, tell them I sent you. They are very accurate with their machining, just tell them what you want.
If you have further questions, you can email me.
For any Pontiac blown application, I highly recommend adding a 2nd keyway on the crank snout. While you are having it machined, be sure to give the machinist your hub or balancer as well. Best to you.
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
The Following 2 Users Say Thank You to Steve Barcak For This Useful Post:
Old 10-10-2022, 03:07 PM
Frank is located in Sun City.
Old 10-12-2022, 09:25 PM
Jromaine87 Jromaine87 is offline
We had to send mine out to mile high, that’s who Frank recommended.
Old 10-16-2022, 11:07 AM
KGTO's Avatar
KGTO KGTO is offline
Donny Bonahoon in Havasu
1967 GTO 416 5-spd streetcar 11's on HP low 10's 150 shot
1965 GTO 10-71 Littlefield high-helix retro/Bird (untuned) 8.44 @159 3500+lbs 10.5W's SOLD!
1964 421 GP-Sold
6.0 cert. Fiat bodied altered blown alcohol Pontiac IAII-Sold
Old 10-16-2022, 11:39 AM
Gator67's Avatar
Gator67 Gator67 is offline
Mike Zimmerman has done a few Pontiac engines for me. He's doing an LQ4 for my son right now.
The Following User Says Thank You to Gator67 For This Useful Post:
Old 10-16-2022, 01:14 PM
Mr Twister's Avatar
I agree about the second keyway. 3 shops around me declined to do it. Even Butlers balked at doing it, until I said I would buy a crank if they would add a keyway to it. I did send my balancer to them and it was not returned. I had put my name on it with tape and they found it an returned it. (Mark your parts.)
