Old 02-07-2022, 12:16 AM
Steve Barcak's Avatar
Default Has anyone put the new 5spd TKX Tremec in their Poncho yet?
I guess it has been out a bit over a year now. Was wanting to know if anyone has put on in a 70-81 Bird? Mine is a 4speed and I really do not like it. thinking of the 5 spd swap
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 02-07-2022, 01:25 PM
65madgoat's Avatar
Default TKX videos
Friend has - super easy. Well worth it.
Videos of putting one in a tighter tunnel A-body are here on youtube:
https://www.youtube.com/playlist?lis...1VWcnjCvPVLakF
Old 02-07-2022, 11:26 PM
lamans71's Avatar
lamans71 lamans71 is offline
Wow that may not be a super tough swap if you have a lift, but it would be a bear without one.
Old 02-07-2022, 11:29 PM
tom s tom s is offline
If you don’t have a trans Jack it is still hard with a lift!Tom
Old 02-08-2022, 12:30 PM
I'd sure like to see what it looks like installed from inside the car, console fit, what handle he used etc. any pics avail?
Hosting-
Phil 2:11
Old 02-08-2022, 12:31 PM
I've done every type of mod and repair there is and have never used a lift.
I do have a pit and love it
Hosting-
Phil 2:11
Old 02-08-2022, 01:06 PM
rontiac's Avatar
rontiac rontiac is offline
I'm awaiting my TKX package from American Powertrain.
Some good info in this thread:
https://forums.maxperformanceinc.com...d.php?t=854681
http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=143670&dateline=12211  78868
1965 LeMans Post Coupe..............I'm not waitin for the undertaker....I'm lookin forward to the uppertaker!.....
Old 02-08-2022, 02:05 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
i recently got a lift and a trans jack within the last two years. its a game changer if you can make it happen im 53 and i can get stuff done that i last did at 20 lol
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 02-09-2022, 06:00 PM
lamans71's Avatar
Which is like saying I have a stationary lift . It's just semantics if you have a pit then you have the same ability to get under the car while standing to do the work vs laying on your back on the driveway.
My point is that this swap done on your back with the car one foot off the ground on jack stands would be significantly more difficult, not that it cannot be done that way just far more difficult.
I have done tons of repairs under a car laying on the driveway too, but that was much easier to do when I was 20 or 30 and even 40. Now at 60 I may not have the same desire for that type of experience, especially given the weight of that TKX tranny.
Old 02-09-2022, 07:51 PM
AND these transmission are bigger and heavier than a Muncie or alu ST-10!Tom
Old 02-09-2022, 10:20 PM
gtospieg gtospieg is offline
I bought a Harbor Freight trans jack($140 with 20% off coupon)for just this purpose. No telling how many times I'll be able to use it, 3 so far, before it dies.
Old 02-09-2022, 10:30 PM
Does it go high enough to use with a lift?Tom
Old 02-10-2022, 10:30 PM
No...on my back, just like the good old days.
Old 02-11-2022, 12:16 AM
Formulabruce's Avatar
Test fit one in a buddies car. Used a Silversport version. We used a 400 shortblock and a tractor with a engine leveler and car front tires up on 16 inch
wooden blocks. Put the engine, clutch and trans in at once.
He bought the factory looking shifter handle and its fits dead on in the factory "porch" on the tunnel. There is, however, like 1/4" clearance in a couple spots near the toploader edges but it does NOT touch. Silversport made him a driveshaft and we used the silversport Cross member, factory bellhousing, M22 clutch disc
and 11 inch clutch.
Best to get one made to fit the second gen F body. .
I think he was at $ 3,600 for the kit with cross, Drive shaft, shifter handle and
stock looking trans mount.
Old 02-11-2022, 02:15 PM
racerboy's Avatar
racerboy racerboy is offline
Following this thread now. I am pulling the RA III out of my '70 TA and going with a 455 stroker engine, and have been toying with the idea of putting in one of these 5-speeds in place of the Muncie, esp. since I have the 3.73 rear and the car is just not a lot of fun cruising down the highway.
Three times the sound peaks, falls back, peaks again. A throttling back to cruising speed, a dwindling grumble of thunder and...gone.
The frogs take up where they left off.
The Following User Says Thank You to racerboy For This Useful Post:
Old 02-11-2022, 03:29 PM
racerboy...Do it, you'll never regret it. 3.73 x .68 gives you a 2.536 rear gear. Your 455 will love that almost as much as your wallet.
The Following 2 Users Say Thank You to gtospieg For This Useful Post:
Old 02-11-2022, 11:20 PM
racerboy's Avatar
I actually filled out the SilverSport form today a little while ago just to get some numbers on the package for my ‘70 TA.
Old 02-12-2022, 09:12 AM
gman005's Avatar
gman005 gman005 is offline
I just put one in my 72 Lemans. I had to cut the tunnel a little. I wish I knew about the Silver sport 1st as they modify the tail housing and shifter to fit without cutting. Now I am looking for a shifter boot 6.25x 6.25. So I can cover the hole.
A new best of 9.135 @ 145.41
71 Lemans Sport.
72 Lemans Sport.
Old 02-12-2022, 07:06 PM
R 70 Judge's Avatar
The TKX quote I received from silver sport was around $5900. That was with a reproduction bellhousing and not the SFI QuickTime deal. There were some things I could probably skip but it was a very complete quote.
James
1970 Trans Am
Spotts Built 484" IA2, Highports, EFI Northwind
Terminator X sequential EFI fabrication and suspension by
Old 02-12-2022, 07:09 PM
R 70 Judge's Avatar
In the car in your signature picture? If yes are you running the hydraulic bearing or manual linkage? How are you liking it?
James
1970 Trans Am
