Distributor gasket
Seems like putting a gasket on the bottom of the distributor can be easily overlooked. What are your opinions on using a gasket or not?
Not using a gasket will most likely result in an oil leak.
leaving out the gasket could increase the chance for stuffing the distributor gear down on the oil pump shaft and causing oil pump damage
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
ditto on the above with respect to leaks.
also, IIRC, i read somewhere that the distributor gasket can be used to help set the endplay or clearance of the gear mesh. end play is set on the dist shaft itself, then with different thickness gaskets you can tailor the standing height once installed. that is, of course, one is that anal.
costs too much |
Tightening up distributor endplay too much and not using gasket may cause glitter in oil and binding ignition mech. advance....
At least .040" endplay using gasket is what Pontiac uses. |
Off the top of my head, I can't thing of one V8 that came out of Detroit that either has a gasket or an O-ring on the distributor....
North Dakotas fastest REAL GTO 10.10 @ 131 MPH in the 1/4 Hoping to get it back together some year. www.jandjrepairandrestoration |
Just Checking, Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi. “Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill |
Guess I will have to work on my proofreading skills.
Stewart
The picture shown was taken after the engine was running awhile and as you can see no oil leakage. I glued a gasket to the distributor using Black RTV, and setting in place to dry.
