600 Cubic Inch Small Block
Did anyone see this article last July?
http://www.enginelabs.com/news/cfe-d...l-block-engine 4.6" bore spacing and 10.2" deck height Small Block Chevy Spawned the discussion linked below on YB. I think I have seen similar threads here. http://www.yellowbullet.com/forum/sh...d.php?t=588703
Jim 71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas |
Basically says that NASCAR and the CFE people were not afraid to move the bore spacing, still call it a SB Chebby, and raise the deck height.
And yet the Milk Toast Boys say the P block MUST stay at 4.625 Bore Spacing or it isn't a P motor. Typical. Tom V.
The other thing that I find interesting is that the article says is they can go 4.5" bore with the 4.6" bore spacing.
sure does look a lot like a big block Chevy
"The democracy will cease to exist when you take away from those who are willing to work and give to those who would not." Thomas Jefferson |
Who are the "Milk toast boys"?
Those guys at CFE are freakin dang good,I get more and more impressed with there stuff everytime I look at it......I'm sure that 600" motor will put up a great # and be pretty reliable on the track.
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz “It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life” Notre Dame Head Coach Marcus Freeman 69 GTO NHRA Super Street Car 2860lbs 10.890@157.08 MPH in Iowa in June’23 ,157.56 MPH in Gainesville in March ‘23 |
if I read it right they are going with the 400 2.65" main with the big stroker. Something that needs to be addressed, reducing the main size, with the aftermarket Pontiac blocks.
Can any aftermarket block ( technology and cost wise) have a 2" main cast and then let the buyer machine the preferred diameter?
Stan
Big inch "small block" Chevy's have been pretty common here for years now, typically low 500 CID but recent "Track Sport" Jetsprint engines have been 540 and now 570 CID. Engine weight is just 190kg. HP per kg is pretty good !!!
Runs a billet block but no specs on bore spacing Results in 2g acceleration ans 5-8g cornering force in a small boat . Always interested in any Brand X builds out of the square so to speak. Good to see long held limitations removed (no matter how much $$$$ it costs LOL) I beleive we can learn alot from "looking over the fence"
Working on going faster (and now staying dry at the same time !!) |
Yes, Lynn participated in the project. But done that? You need to recalculate your program...... error, error, as the robot says.
Is your's the only project that this has been done on? Stan
it's in your court, you brought it up, you can verify the specualtion or statement you made.
