Old 03-05-2024, 11:28 PM
ddcrank ddcrank is offline
Default 1970 GTO front brake calipers
Looking for a pr of 70 GTO front brake calipers.
Old 03-06-2024, 04:16 AM
Scott Thelander's Avatar
pretty sure I have a pair
5463636 and 37 ??? what are the castings you need ?
what was the build date on your 70 ?? I forgot seems it was a late one ...
I will look tomorrow afternoon when I get back home..
EB on the master cylinder in 70 ????????
Scott
Old 03-06-2024, 08:29 AM
Thanks for looking Scott. The car was built the 4th week of October 69 for an early model 70.
Old 03-06-2024, 08:39 AM
I'm not sure when the cut off was for part numbers on the brake calipers. Not sure if they used 69 parts until they ran out or if 70 model got a all new caliper even if it was a early car. I think you are correct on the master. It needs to be the square one with bleeders for power front disc.
Old 03-06-2024, 04:20 PM
Can you id this one Scott? When I ordered parts I just rolled the dice and said 1969. Everything fit but I got a little lucky I guess.
Sorry for the brief hijack.
Sent from my moto g stylus (2021) using Tapatalk
Old 03-06-2024, 10:45 PM
Dan
1970 was 5469700. 5469701
According to my research .
Dates are stamped not cast and are hidden when installed…
I will/can check dates i didnt have a wire brush with me. They are in the truck and i will later
Scott
ID:	630002   Click image for larger version
ID:	630003   Click image for larger version
Old 03-06-2024, 10:51 PM
Default Caliper
636 is 69 L
The Following User Says Thank You to Scott Thelander For This Useful Post:
Old 03-06-2024, 10:56 PM
Let me know what you want for the 70 calipers.
Old 03-08-2024, 10:29 AM
Thank you Scott again for all your help and having the calipers I need. We have been doing business together for many years now and you never disappoint. Thank you for sharing your knowledge and great parts with us.
Dan
Old 03-08-2024, 10:32 AM
Thank you PY Forums. 70 caliper order has been filled.
