Old 07-14-2008, 05:20 PM
dayton maaco dayton maaco is offline
Default Old wiring harness
Iwould like to reuse my old wiring harness,how would I go about cleaning the harness before reinstalling?
Old 07-14-2008, 07:49 PM
GStage1's Avatar
GStage1 GStage1 is offline
Unwrap the electrical tape/cover, put on some rubber gloves, soak a rag with some mineral spirits and wipe down all the wires. Rewrap the harness with new tape and you are set.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 07-14-2008, 08:26 PM
78 GHOST 78 GHOST is offline
Brother, with all the quality work you've done, I'd urge you to consider a good M&H harness.
They are expensive, but dead nuts correct for your application.
Time isn't nice on wires. My car has all new harnesses and I've noticed the lights are much brighter than they used to be. No funky age related issues.
I didn't want to trust my project to old wires when a good replacement was readily available. I know they're probably ok for now, but what about down the line?
____________________________________
"I work in high speed aluminum tubing."
Old 07-14-2008, 08:42 PM
judgethis judgethis is offline
Im with 78 GHOST with the time spent unwrapping cleaning and rewrapping and making sure you wrap them correctly spend the money with M&H. Especially the engine and outside harness those tend to get hard and brittle being exposed to the elements. If your going to take it off might as well put a new on back on. M&H is also dead on with color and fit.
If you want to clean them up though go with GSTAGE1's idea.
