Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
383 (301) stroker engine 475HP
Hate to do this but for personal issues I need to sell this. I bought this from Tom S on this board and you can read about it here for all the details:
http://forums.maxperformanceinc.com/forums/showthread.php?t=710524&highlight=301+stroker I installed in my 79 firebird and fired it up, and it sounds really good. This has a 326 crank, custom pistons and has forged rods. Heads and intake done by SD Performance and all port matched by Dave. There is over $6,000 in parts alone and was built by Joe Sherman. Timing is all set and ready to fire up. I hate to sell this, it really is a great engine and puts out a ton of power. It uses the 301 turbo block which is ass thick in the mains as the traditional Pontiac blocks. If you want a lighter engine by at least 100 lbs and makes great power, this would be perfect. I would like $5,000 plus shipping. I had it shipped from LA to NY last year and it was $275. |
Just wanted to add more details in this engine. The heads are 15 and ported to flow 263 @.600 while being port matched to the custom intake manifold. Comp Cam is a solid roller with 230/238 @ .050 and .616 lift. Custom forged Pistons, cam and ignition is all dialed in, ready to drop in a car and run.
TTT
Cool engine! The Dyno Sheets are wayyy too blurry to read whats make for power and tq?
Build it Right Build it Once!!! Just another Engine Builder from the Northwest lol |
478 HP over 400 TQ across the RPM range.Engine was shut off at 6000 while still climbing.There is 500 in it easy.Tom
TTT
Any interest in this? Can go down on price some,
Price lowered to $4,000. Need to sell!
how much vacuum did this motor pull?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
I don't know. Tom S had this built and when it ran on the dyno don't think they measured it. It was intended for a street car, and from the way it sounds probably around 16-17.
Never did a vac reading.Tom
PMs have been answered
I had some inquiries on more details on the engine so I summarized them here.
Some details on the engine, 9.2 compression, revs to 6000, dynoed at 475hp, ignition is all set. Turbo 301 block, the main webs are as thick as a 400 block. No block work needed to make this work except boring, align hone, standard procedures. Mains were doweled and has a short block fill. Heads are 1968 #15, with new 2.05 valves, ported by SD Performance, flow at 260 @ .600 The thrust bearing uses a .071 steel thrust bearing spacer designed by Nunzi. It can't fall out because held in by a groove. Crank is a 1963 326, but any 326-400 crank will work. Journal diameter and width is the same as a big block Chevy. Uses forged L88 rods and a custom forged piston to make the compression work. Rod is 6.135 and bore is 4.030. Motor work done by Joe Sherman. www.joeshermanracing.com Used a edelbrock torker single plane that has been cut down in the runners and welded back by SD Performance. Also was port matched to the heads. Manifold is beautiful work by Dave, you can't see the welds. This makes the short deck work because it is 1" shorter deck height than standard pontiacs. Rockers are steel rollers with 1.65 on intake and 1.5 on the exhaust. Roller Cam Lobe #4639B and 4641B on a 111.230-238@ 50 and 4070-4170 lobe lift .016 lash. |
Still for sale. Pulled from car and inside my dry garage.
301 motor
Where in New York are you located
Albany/Saratoga
I hope someone else realizes how good of a deal this is!
That 475hp is probably most peoples 500+! I keep thinking this motor in a 63 tempest set up to handle with fat tires and a wide body kit with a 5 speed, i need to win the lotto lol!
I built it for a 63 tempest auto transaxle car in mind.Tom
You takin Money at par. Ed
I'm thinking this in my 67 fbird would be an awesome sleeper motor up here where most guys know **** about Pontiacs. LoL. Ed
