Old 03-06-2021, 01:19 PM
NeighborsComplaint's Avatar
Great color and nice job! That saddle interior is one of those odd combinations people sometimes ordered. A buddy bought used Torino SCJ that was red with a gold interior. Story was the original owner thought the color chip looked more like a parchment when he ordered it new..
I think a set of Judge stripes in the right color might pull the exterior and interior color together. Either way, it's still a very nice car.
Triple Black 1971 GTO
  #62
Old 03-07-2021, 11:10 AM
scott70's Avatar
scott70 scott70 is offline
Thanks....I always thought black would of been a better match to the turquoise but now that I see it together the saddle/ dark saddle is pretty good and unusual at the same time. Finished up rear door panels and seat yesterday. When the weather warms and the paint sits a little longer we will put the black call outs on it and install the original 69 judge stripes in white/ black/red. I talked to the original owner back in 86 and I believe they bought it off the lot but I guess it still could of been ordered by an individual.
1970 GTO 455 4 speed #matching,, 3.31 posi.Stock manifolds. # 64 heads.A factory mint tuquoise ,69' judge stripe car. 8.64 @ 87.3 mph on slippery street tires.Bad 2.25 60ft.Owned since 86'
  #63
Old 03-07-2021, 12:14 PM
SD455DJ SD455DJ is offline
Scott70, That looks frickin amazing!..and will look even better with the D98 R-B-W stripe and black decals on it. I love the Mint Turquoise and saddle combo!
Dennis
  #64
Old 03-07-2021, 01:13 PM
scott70's Avatar
Dennis
Thanks Dennis,,,can't wait for it to be done and hit the road! I'm pleased with the way its coming out. IMO the CC could use a little more wet sanding here and there. With the original 455 at 490hp 570trq it should go pretty good. Been watching your 455HO build !!!
  #65
Old 03-15-2021, 04:54 PM
scott70's Avatar
Well its home. Everything done except for decals and stripes which we'll do in a couple of months. Could use more wet sanding but I'll leave that for now. Also waiting for the 15x8 rally 2 wheels for the back which were ordered in August from wheels vintiques through jegs. I've got the 255/60-15 bfgs but nothing to put them on. I ordered a custom 4.75 backset but month after month they say they're waiting for either the rings or the centers so they can weld them together. Fronts are 15x7 with 4" BS with 245/60-15.
ID:	562717   Click image for larger version
ID:	562718   Click image for larger version
  #66
Old 03-15-2021, 07:24 PM
vertigto's Avatar
vertigto vertigto is offline
She is beautiful...you should be very proud.
  #67
Old 03-15-2021, 08:33 PM
Mike Davis's Avatar
Very nice!!
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
  #68
Old 03-18-2021, 08:29 PM
... looks frickin amazing!..and will look even better with the D98 R-B-W stripe and black decals on it.
Dennis
Agree, the Mint Turquoise looks great and the stripe will set it off even more. Congrats!
  #69
Old 03-22-2021, 01:18 PM
scott70's Avatar
Thanks for the compliments. Question,,,I have Hagerty... I raised value to 37,000....sound reasonable? No one around here I believe does classic car value and I'm not sure I really need to.
  #70
Old 03-22-2021, 01:48 PM
Scott, I'd go 45-50k minimum on your car. The premium is relatively cheap compared to trying to find another like it...which you won't.
Dennis
  #71
Old 06-21-2021, 04:20 PM
steve v's Avatar
steve v steve v is offline
Originally Posted by scott70 View Post
Went to put in the black rectangle vents in the door jambs by the door lock posts and there's no place for it. These are nos rear 1/4s and never saw where these have no openings cut out for the vents. Did the eliminate the vents on the 71-72 cars?
Scott, Here's a pic that should help w/the vent location. HTH!
  #72
Old 06-24-2021, 02:47 PM
scott70's Avatar
Thank you to Steve for sending me tracings of the openings. Got driver side done....just didn't look right without the vents in my 70. I put the originals back in. Didn't even realize until after that the nos rear 1/4's don't come with the cutouts
ID:	568777   Click image for larger version
ID:	568778   Click image for larger version
ID:	568779   Click image for larger version
  #73
Old 06-24-2021, 02:53 PM
padgett's Avatar
padgett padgett is offline
Yes, asto-ventilation replaced vent windows on F-bodies (69 ?) and a response to a NHSA finding about exhaust leaks.
ps just for S&G the '72 wagon was the last A-body to have vent windows.
Web Site
  #74
Old 06-25-2021, 05:50 PM
steve v's Avatar
Scott, glad those helped out. It's always a little scary cutting around freshly painted parts.
Just to be different the 70-72 A-body converts did not have the vents, I guess they figured the rag top leaked enough air that they didn't need them!
  #75
Old 10-16-2021, 05:56 PM
scott70's Avatar
Been poking at this now and then,,,attempting to do the stripes myself. Bought the application gel that they offered and tried the front fender. Big time bubbles caught in the middle. Tried poking holes with small needle but just too many. Ripped it back off and ordered another fender stripe. Did the door and tail piece today and used soapy water solution instead. Made sure to do up and down with the squeegee. Came out better but still some bubbles. Must be an art to this. Waited 3 hours to take off outer layer like they wanted. Will some time help out?
The 2nd pic is just one spot of bubbles.
ID:	575348   Click image for larger version
  #76
Old 10-17-2021, 02:23 PM
West Coast GTO's Avatar
West Coast GTO West Coast GTO is offline
Time doesn't appear to help. Trying to pop bubbles with a pin didn't much help me. Did you possibly use a hair blow dryer to work the bubbles? That seems to work better on mine. Also, Did you free hand it or dry fit decals on the car?
Name:	Side stripes1.JPG
ID:	575428   Click image for larger version
Name:	Side stripes2.JPG
ID:	575429   Click image for larger version
Name:	Side stripes 3.JPG
ID:	575430   Click image for larger version
  #77
Old 10-17-2021, 03:05 PM
What kind of squeegee do they give you? I've never applied Judge decals but I've applied a lot of them over the years to other things... Model airplanes mainly. I have found the best squeegee to be something very firm such as the edge of a credit card or even soft wood like the cheap yard sticks they give you in a hardware store or even better, balsa wood. Soft enough to conform to the curves of the surface but firm enough to really press down the actual decal surface.
I've used the soapy water method many times but only when it's an adhesive backed sticker. It does help to use a little heat while you are burnishing with the squeegee.
Also, l always start from the midpoint and work out in both directions as l go.
Just some thoughts.
  #78
Old 10-18-2021, 09:26 AM
scott70's Avatar
The squeegee Phoenix sends is pretty stiff plastic. I sprayed both stripe back side and vehicle with the water/ soap solution, laid down stripe and started in the middle. Took squeegee and worked the solution out the edges. Can't see if there is any bubbles left until you pull off outer layer 3 hours later which is now too late. Going to a professional today and ask if they can do any better. It doesn't look horrible but I'd like it to lay perfectly flat and smooth.
I did use a needle and a hair dryer which can get rid of alot of it but not the smaller ones.
The Following User Says Thank You to scott70 For This Useful Post:
  #79
Old 12-04-2021, 09:48 AM
scott70's Avatar
Finally was able to apply stripes with no bubbles. Had a guy show me what I was doing wrong.
ID:	579098   Click image for larger version
  #80
Old 12-04-2021, 10:05 AM
tempest1964's Avatar
From what I can see, that looks great! Can you share the tips from the pros?
The Following User Says Thank You to tempest1964 For This Useful Post:
