Old 12-22-2020, 07:14 PM
68WarDog's Avatar
68WarDog 68WarDog is offline
Default Vacuum gauge
I'm going to be installing a vacuum gauge in my 70, because with a cam having lot of overlap I like to stay upon my tune. How many still tune their engine using one? Pontiac at one time installed them on several models .Why was this feature discontinued?
Old 12-22-2020, 09:38 PM
Formulajones's Avatar
I use them temporarily on occasion If I want to play with power valves on a new carb/engine setup, but never had the need to keep one on a car permanently.
https://youtu.be/XqEydRRRwqE
Old 12-22-2020, 09:54 PM
STEELCITYFIREBIRD's Avatar
I believe they were marketed on cars as a fuel economy gauge. YMMV !
Old 12-22-2020, 10:55 PM
Half-Inch Stud's Avatar
My VAC gauge is a permanantfixture in the 68 GTO.
Old 12-22-2020, 10:56 PM
74Grandville 74Grandville is offline
a vacuum gague can be used for many things, but i would rather an 02 sensor. even that can be a set and forget once you get it right.
1979 Firebird Trans Am 301/4spd (Now 428)
1977 Firebird Formula 400/Auto
2007 Grand Prix GXP 5.3L
Old 12-23-2020, 12:20 AM
64speed's Avatar
64speed 64speed is offline
I have a Stewart Warner motor minder going in my car.
Old 12-23-2020, 07:55 AM
steve25 steve25 is offline
I had a factory gauge in my 65 GP and I believe it was standard in the GP with the automatic, it was graduated in both inches of vacuum and with 3 blended colors such that the left side ( green ) was labeled economy and the far right side which was Red ( and zero ) was labeled power. The middle range color was yellow and if I recall right if the needle was centered it was reading 10 to 12 inches.
The motor in the car was the standard 325 hp 389.
I think that feature was dropped because a lot of owners would hardly pay attention to a oil pressure gauge after a while, no less a Vacuum gauge, or that it was a hardly requested option and could only be used with a console to mount it to.
