#81
A Torker 2 or RPM would also be a good choice to feed your beast. I don't have any hood clearance issues with my 68 Bird with dropped air cleaner. |
#82
Don't have the heads cut until you actually measure them. 100 is a nice round number and I would want to insure that is what the chambers measure. Also, measure both heads since they might have received different clean up cuts in the past. The Rhoads lifters will increase your effective compression ratio since it will mimic a smaller cam at idle. Just my 2 cents, but I'd be shooting for a true 9.3:1 ratio.
edit: According to the Wallace website calculator, a change in compression ratio from 9.3 to 9.5 on a 450 horsepower engine will result in a whopping 2.6 horsepower increase.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon in progress. Last edited by lust4speed; 10-22-2012 at 01:36 PM. |
#83
Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s |
#84
IIRC, a full point compression increase results in about 4% hp increase, so increasing a half a point (9:1 or so to 9.5:1) should get me 2% increase, or about 10 hp on a 500 hp engine. Thanks Scott
#85
If you've read on any of the previous Crower 60243 cam threads more than likely it will need advanced 4 degrees. I used the short Mr gasket 2 degree offset key on the cam to do mine unless you have a good adjustable crank gear. My edelbrock mulitple keyway gear moved it 8 degrees in the advance position.
Illinois Outlaw Gassers 6.27@107 9.97@131 |
#86
Thanks Scott
#87
Yes, they are not ground correctly. Mine degreed in at 112 stright up and need to be at 108-109.
#88
Another cam option is the Comp XE274H - 230/236 at .050, .488/.491, 110 LSA, makes power from 1,800-6,000.
Should I run 1.5 or 1.65 rockers? I'm assuming 1.5, since that's the ratio that the cam specs are given for. Thanks, Scott
#89
Got the short block home last night. Nice looking stuff. Need to do some research on block prep. Have one of the more popular engine building books, but will also do a search here.
Thanks Scott
#90
Block Prep
Some info from that I found here from a 10 year old post:
"Improve oiling? You know, there's just not a lot that really needs to be done to a Pontiac to improve oiling for street performance. Plenty of very strong Pontiacs running around out there with the oiling systems just as the engineers designed them. That said, there are a few things you can do that certainly won't hurt. First - remove all the casting flash in the oil drainbacks in the heads and around the lifter bores in the block. That will help oil drain back to the pan. Second, modify the main bearing oil feed holes. If you look at the holes in the main bearings you'll notice they are significantly smaller than the holes in the block. The easiest thing to do is to take a small rat-tail file and lengthen the oil hole in the bearing along the groove until it's just as wide as the oil hole recess in the block. If you're really brave, and prepared to do even more work, you can drill holes in the bearings to match the location and size of the holes in the block, but I feel this is overkill. That didn't stop me from trying it once though - http://misc.willbaker.com/440engine/drilledmains.jpg The reason the larger holes are offset some from the original holes in the bearings is because the original oil holes in the bearings are inline with the passages in the block that feed the cam bearings. The feed passages to the main bearings come down from the passenger side lifter galley at an angle, so I drilled new holes to be inline with the actual feed passages in the block. Like I said, this is overkill for a street engine. If you really feel like messing with this, elongating the holes with a file as mentioned above will get the job done. Be sure to thoroughly debur the bearing shell when you're done. Third - block off the bypass valve in your oil filter adapter. Remove the small screw, spring, checkball and valve itself then either drive a small core plug in and stake it in place or tap the hole and insert a small pipe plug. If you keep your oil changed and use a quality filter you don't need or want that bypass there. Fourth - thoroughly inspect your oil pump. This should be done on ANY new oil pump but I'm surprised at how many people feel they're fine to install right out of the box. Disassemble the pump and clean it thoroughly to remove any debris that might be present, especially around the check ball. Check the depth of the gears to the base of the pump, you don't want more than .003". Fifth - chamfer the oil input hole in the block where the pump bolts up so that any small misalignment of the pump output hole to the block input hole won't present a restriction. On most pumps I've seen, the passage to the block through the pump body is cast, not drilled and not always round. You can also run a drill through this passage while you've got the pump apart to remove any restriction to flow imparted by the roughness or out-of-roundness of the casting. That's about all I can think of for now. As mentioned, for a 99.99% street engine this is just about all unnecessary, but if you're like me, you do it anyway just to say you did..."
#91
Karl |
#92
In researching my recent build, I found the prevailing thoughts now are to leave the bypass system working on the filter housing.
For my oil pump, I bought one from Ken Keefer aka the Pontiac Dude and had him blueprint it and install a pressure shim to get the pressure up a little from the rating of 60, but not so high as to cause bearing wash. Works real well for the same price as one from Summit. |
#93
Scott
#94
1972 LeMans 461 stroker 10.3:1 Edelbrock D ports Scorpion 1.5 rockers Comp Cams "Stump Puller" roller Holley Ultra Street Avenger 770 Ram Air III exhaust manifolds 2.5" pipes Dynomax VT w/crossover Edelbrock Performer RPM TH350 2.78:1 10 bolt |
#95
What kind of pistons get you 10:25-1 with 87cc chambers?
10:25-1 with aluminum heads should be fine with 93 octane.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
#96
From JEGS:
-5cc flattop SRP forged pistons. Pontiac 461ci Rotating Assembly Compression Ratios: 11.5:1 with 75.2cc 10.4:1 with 85cc 8.5:1 with 111cc http://www.jegs.com/i/Eagle/356/51400/10002/-1 Now of course SUMMIT says differently: Piston Material Forged aluminum Piston Style Flat top, with two valve reliefs Piston Head Volume (cc) +5.00cc http://www.summitracing.com/parts/ESP-51400030/ From Eagle website: NOTE! - compression ratio calculated assuming uncut block and .040" head gasket, 87CC head part number engine CID crank rods pistons bore sizes comp. ratio price 51400 461-468 cast 4.2500" 6.800" H-Beam -6.0cc forged Mahle .035 .065 9.94 1718.75 51500 461-468 4340 4.2500" 6.800" H-Beam -6.0cc forged Mahle .035 .065 9.94 2093.75 51501 488-495 4340 4.5000" 6.800" H-Beam -6.0cc forged Mahle .035 .065 10.47 2093.75 http://www.eaglerod.com/index.php?op...d=33&Itemid=40
1972 LeMans 461 stroker 10.3:1 Edelbrock D ports Scorpion 1.5 rockers Comp Cams "Stump Puller" roller Holley Ultra Street Avenger 770 Ram Air III exhaust manifolds 2.5" pipes Dynomax VT w/crossover Edelbrock Performer RPM TH350 2.78:1 10 bolt Last edited by DevoBuzz; 10-23-2012 at 06:50 PM. |
#97
Thanks Scott
#98
Did a bit of research on the intake - leaning towards a Performer RPM.
Still on the fence on the cam, but leaning towards something a tad smaller - maybe the Comp 268H - - 224/230 @ .050, 477/480, 110 LSA, makes power from 1,600-5,800. However, with a somewhat tight LSA, I'll have to check the dynamic compression ratio. I can also dial back the compression a bit if necessary, since I haven't had the heads milled yet. Also think this cam should work with a stock converter and Ram Air exhaust manifolds. If I want to wake it up a bit, I can always swap the 1.5 rockers for 1.65 rockers. Thanks Scott
#99
Just ordered a timing chain and roller cam plate from Scott Sims - http://forums.maxperformanceinc.com/...d.php?t=390936
Also ordered Rocky Rotella's book on rebuilding Pontiac V8's (already had Jim Hand's book) - http://www.amazon.com/Rocky-Rotella/e/B004AQ78L4 Scott
#100
Best cam choice I've seen mentioned thus far is the Crower #60243.
The deal with the ICL on the #60243 cam is NBD really,all cam installs should be degreed,no matter what brand of cam they are. And IMO that cam wont need Rhoads lifters in a 455,the idle will still be pretty decent. I'd stay away from the Comp catalog/shelf grinds myself. If you want a cam from Comp,I'd recommend custom ordering one,that is after consulting with someone that knows what pontiacs prefer in regards to cams. JM2¢ ~ FWIW Bret P. |
