Old 03-16-2022, 05:21 PM
rontiac's Avatar
rontiac rontiac is offline
Arrow new hydraulic rollers.......
So, I'm wondering if there's any feedback yet on the new evolution hydraulic roller lifters from comp cams.................
https://www.compcams.com/evolution-r...set-of-16.html
They look promising............especially since I lost a lobe on my cam and need to purchase new lifters.
I see they're new, I got the email today, but am wondering if anyone has any info on the low down.
http://forums.performanceyears.com/forums/image.php?type=sigpic&userid=143670&dateline=12211  78868
1965 LeMans Post Coupe..............I'm not waitin for the undertaker....I'm lookin forward to the uppertaker!.....
Old 03-16-2022, 05:26 PM
77 TRASHCAN's Avatar
After a quick look, I'm not understanding how the lifter body stays in the bore, to keep from turning???
Shut it off
Shut it off
Old 03-16-2022, 05:33 PM
JLMounce JLMounce is offline
The photos on the site state "not actual photo" on each of them. I'm sure there's a link bar, but marketing hasn't created brand specific photos yet.
I too am waiting on some reviews for these.
-Jason
1969 Pontiac Firebird
Old 03-16-2022, 07:00 PM
AG's Avatar
AG AG is offline
After reading online reviews and several articles about them, and talking to the lead engineer I got a set of Johnson HR lifters. They are fully manufactured and heat treated in the US.
Old 03-16-2022, 07:18 PM
tom s tom s is online now
The lifters before this were made in the US by Shaver Enterprise in SoCAl.The new lifters look exactly alike except for the insert of the metering system.Have not talked to anyone that has got a set of them yet?Tom
Old 03-16-2022, 07:20 PM
Site says avail "soon"Tom
Old 03-17-2022, 01:08 AM
Schurkey Schurkey is offline
Appears to use a link-bar system at the top of the lifter.
What's with the "high-performance" circlip holding the lifter together, with the low-performance wire clip hiding inside the "Hydraulic Cartridge"?
BUT if the photo isn't of the actual product...
I like how they talk about patented features without actually listing the patent number.
Old 03-17-2022, 02:00 AM
Brentco's Avatar
Brentco Brentco is offline
From the description, it kind of sounds like the point of these new lifters was to design around QC/production tolerance issues in the current manufacturing. Instead of fixing the QC for its existing lifters, Comp designed a new lifter that doesn’t need as exacting QC?
1976 Trans Am Buccaneer Red
468ci, 10.5:1 CR, 87 CC RPM CNC e-heads, HR 282/288, 230/236, 561/.573 lift, Johnson Lifters & HS 1.65 Rockers
Old 03-17-2022, 06:35 AM
rontiac's Avatar
I thought I read that the clips are there so they can be rebuilt?
I could understand having the rebuild function if they were used for racing applications, like solid rollers in extreme conditions. Why would you want to rebuild hydraulic rollers that I think would mostly be used in street applications.............?
Sounds like another case of planned obsolescence..........
Old 03-17-2022, 07:47 AM
grivera's Avatar
grivera grivera is online now
There was a thread about this sometime ago. The way I understand it having the insert function allows all lifters in this series to be produced with a specified bore so easier to control tolerance. Theoretically, if one gets a "ticker" just replace the cartridge instead of the whole lifter.
Will Rivera
‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears
'64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded)
The Following User Says Thank You to grivera For This Useful Post:
Old 03-17-2022, 10:00 AM
78w72 78w72 is offline
shows "in stock" now & lets you add it to cart & place the order.
these look like a nice design & says they can be rebuilt by the owner in their garage if/when needed. claims to cure the noisy ticker issues of previous designs. will have to wait for the reviews when people start using them....
Old 03-17-2022, 10:07 AM
Lee's Avatar
Lee Lee is offline
I've had a set for a few weeks now. They are for a car that probably won't be on the road until the summer, so it will be a while before I know how well they do/don't work.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'.
Old 03-17-2022, 10:30 AM
Folks have been rebuilding lifters since hydraulic lifters were invented.
The lifters in my K1500 were pulled-apart for cleaning and inspection. Nothin' to it--if the lifter is basically healthy to begin with.
My guess is that "rebuilding" in the Comp Cams sense means "throw away the "cartridge" and buy new ones."
The Following 2 Users Say Thank You to Schurkey For This Useful Post:
Old 03-17-2022, 12:10 PM
70GS455 70GS455 is offline
Can't rebuild hydraulic roller lifters with the link bar riveted in at home
Sent from my SM-T817V using Tapatalk
Old 05-05-2022, 09:14 PM
rohrt rohrt is offline
I'm trying to get some feedback from Butler if they have used these lifters.
Old 05-07-2022, 07:25 AM
Thought some find this reply back from Butlers interesting:
"The 85701 Pontiacs lifter itself hasn’t been out that long, but the cartridge inside the new style lifters is from overhead cam engines so there are literally a million of those out there running for many years. Also they’ve been testing the LS version of these lifters for about a year both in engines on the dyno, on the Spintron and in cars.
We build and tested a couple of engines with them with no issue.
As with every part, it’s the engine builders call. We’ve had literally every part that we use from every manufacturer fail at some point, including Johnson lifters... "
Old 05-07-2022, 08:46 AM
grivera's Avatar
Great info!
Will Rivera
Old 05-08-2022, 03:58 PM
Tim Corcoran's Avatar
Default Hyd Roller Lifters
Not sure if the new comps will be anything special or not but, I believe the best Hyd Roller currently available for Pontiac are the Made in the USA Johnsons
https://butlerperformance.com/i-2445...tegory:1234800
Tim Corcoran
Old 05-12-2022, 03:57 PM
Angry
and currently not available
Old 05-12-2022, 05:45 PM
TCSGTO's Avatar
TCSGTO TCSGTO is offline
Wow! They have almost doubled in price in just a few short years
68 GTO,3860#
13.86 @ 100
Old combo:
New combo:
636HP/654TQ
1.452 10.603 @ 125.09
