Old 12-08-2022, 11:19 PM
Mook Mook is offline
Default Driveshaft problem??
PY Family……1969 GTO…. 468 with 200r4, driveshaft made by local shop. At first years ago I noticed a circle around the driveshaft, thought it was hitting the X-pipe, muffler shop said it was not. Now there are marks (circles) in at least 7 spots, each circling the shaft…….I don’t see any obvious spots on the undercarriage where it could be making contact… wth…… any ideas… ? I have add coil overs in recent years ….thx
ID:	603267   Click image for larger version
ID:	603268   Click image for larger version
Old 12-09-2022, 03:39 AM
dataway's Avatar
dataway dataway is offline
Looks more like something got wrapped around the shaft ... if it was a Jeep I'd say you got some brush caught in there for a while. Not rubbing on the bottom of the tunnel?
Old 12-09-2022, 07:24 AM
25stevem's Avatar
25stevem 25stevem is offline
Something is rubbing on the shaft hard enough to make some deep grooves that can be seen!
It must be rubbing on something.
My best guess is that You may have bad motor mounts and or a transmission mount, and this is assuming you don't have bad U joints
I do stuff for reasons.
The Following 2 Users Say Thank You to 25stevem For This Useful Post:
Old 12-13-2022, 08:08 AM
Could/would the addition of coil-overs in the rear / lowering the stance effect the clearance between the tunnel and the drive-shaft? Especially during possible bottoming out conditions? Thx
Old 12-13-2022, 08:15 AM
johnta1 johnta1 is online now
If you lowered the stance, that would put the shaft closer to the top of the tunnel?
Possibly on a bounce the shaft is rubbing the top of the tunnel?
Also do you still have the emergency brake cable that goes under the shaft?
When you put the coil-overs on, is the rear end off center now?
Old 12-13-2022, 09:14 AM
My bet is the floorboards make contact. You'd hear that.
Old 12-14-2022, 10:07 AM
I'm starting to believe thats what happening........had the scratches in on one spot before the coilover addition.......
Old 12-14-2022, 11:19 AM
The last time I bottomed out, I thought it was strange I didn't hear metal hitting the ground. But felt something......
Old 12-14-2022, 02:41 PM
Will check the E-brake cables location today......
