Help With Engine Code
Looked at a 1963 Grand Prix and can't find this engine code anywhere. Any help would be appreciated. Looks like top line reads 963D. Thanks.
Curious. I can't find anything close to that. I was thinking maybe the 6 and 9 were a double stamp (like they got a 9 upside down at first so added the 6, or vice versa) but then I couldn't find any code at all with a D in it.
That's the VIN of the car - 963D16380
1963 GP built at Doraville Any other stamped numbers on front? Possibly a service replacement engine.
Could hope it is a 11B or even better 13B!
D'oh! I should have known that. Looking more closely at the photo, there may be some smaller stamped numbers hidden behind the grease, below and to the right of the VIN.
My 61 out of Wilmington also has the VIN on the block that way. Two lines of stamping near the lower left side of that milled pad. EUN and engine code are higher up and more to the right (toward engine center) on that pad. EUN is small stamp size although the code a little larger and located under the EUN. The stamping Stuart sees looks like my EUN size stamp. So try looking beneath that stamp for the engine code..
Sorry for my ignorance on these early cars. Here is the correct code. Should make it much easier to identify now.
According to Wallace racing..
thats a 1963 389 block that originally was a TriPower car.. with Auto Trans -- I hope its still correctly intact... 1963 389 313 HP Code -=266 26-6 Trans = A Comp = 10.25 Cam = 472 Heads = 543797 Carbs 3-2 (F)7013063 (C)7023073 (R)7013065 Block Casting # 543680 John
Not all who wander are lost... 1964 Starchief 4 Dr Sedan - 389 4Bbl - Auto - Pinehurst Green/ Gold cloth 1964 Grand Prix - 389 4 BBl w SupHyd auto 1964 Catalina Safari - 63 389 200r4 auto.. 2.69 POSI rear 1964 Bonneville Vert - 389 4bbl - Auto - Ext Color - Saddle/Saddle int 1965 2+2 - WG 421 4Bbl - 4 spd - Bluemist Slate w White/black int 1966 Ventura 4 dr Sdn - 389 4Bbl - Auto -Orig Color - Barrier Blue |
Well, guess it's not a 421 SD engine.
Still a good find.
