Q-Jet Vacuum Ports
Have a quadrajet on my '79 TA 400 4 spd (not the original carb to the car) and the drivers side vacuum port at base of carb is "blocked" or non functional as is the opposite port on passenger side. What is involved in making these functional so I could then use a ported vacuum source?
Thanks in advance, Joe |
When you say "base" of the carb, where are you talking about? Are they above the primary butterfly's?
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
The logical step would be to "unblock" the port. Or am I missing something?
Vacuum Ports
Ports at the base of the carb above the primary butterflies. Part of the throttle plate.
Can you get a drill bit at them?
