Old 03-17-2009, 04:23 PM
19Pontiac69's Avatar
19Pontiac69 19Pontiac69 is offline
Default What Q-Jet to choose?
Hi,
I have a '69 Custom S conv.with a 350/TH350. From the factory it seems like it had a 2BBL Q-Jet since it has the following codes stamped:
YU code (265HP)
#47 heads
Block cast: 9790079
An earlier owner changed the intake and put on a Edelbrock 1405. The intake has the following codes: F027 / 535255
This tells me that the intake is from 1976-1977 and fitted on 350-400-455 (info from pontiacpower.net)
So my question is what 4BBL Q-jet to choose for this intake/engine? I was hoping to find a good object to rebuild, but need to know what to look for...
Joachim,
Norway
Old 03-17-2009, 04:29 PM
67cruiser 67cruiser is offline
Only view on it, find a p.b.o. 1977 carb. great fulcrum design along witha great float and ease to set-up. hope it helps
Old 03-17-2009, 04:36 PM
Thanks!
I will take a look around to see what I can find
What do you mean with p.b.o?
Edit: Oh...Pontiac, Buick or Olds
Old 03-17-2009, 05:13 PM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
Yes, the 76-80 carbs with the front fuel inlet are are a good one to start with...
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 03-17-2009, 07:24 PM
bignate's Avatar
bignate bignate is offline
My favorite Q-jets are off of '80 to '85 Chevy/GMC 1-ton trucks without specific emissions (10000lbs. brakes) 350 or 454. Dual pulloff, big primary, easily converted to elec. choke some even have elec throttle stop solenoids that I use for A/C cars.
Old 03-18-2009, 04:32 PM
Thank you for your advice!
1969 Pontiac Tempest Custom S convertible
Old 03-18-2009, 04:53 PM
Yes those are good carbs too. The only drawback with them is the side fuel inlet makes routing a bit more difficult. Also some of them have the rear choke pulloff control the secondary air valve. The problem with this is that they are a lot harder to do anything to adjust the opening rate of the pull off to allow the secondaries to open quicker. And most of the ones that have the rear choke pulloff controlled secondary air valve open pretty slow from factory.
If I get one if these in to work on that has the rear choke pulloff controlled secondary air valve, I usually convert over to front choke pulloff controlled secondary air valve and discard the rear one entirely.
Old 03-18-2009, 06:21 PM
bignate's Avatar
The rear pulloff truck carbs have a straight vacuum tube on them and the restriction is real easy to enlarge thereby decreasing opening time. And yes the side inlet does make it a little bit harder to route fuel lines if you use a mechanicle fuel pump but not so much with elec. pumps. I also like the rear pulloff because it unloads the choke faster if you use it. And all the truck carbs I've seen have idle bypass air on them. The 454 carbs used a throttle cable bracket that bolted to the rear carb bolts, it makes for a cleaner installation I think.
