Tri power intake ID please!
Can someone Id this intake? Is it worth $100.00
Thanks a bunch in advance.
69 400 Block, .030 over, KRE eagle stroker kt, KRE,CNC ported e-heads 310 cfm, port match RPM , comp roller 236/245@.05 586/600 lift 110 LS. 1.5 HS roller rockers, 350 Transmission, Red Neck tight 3500 stall converter, Ford 9” with 3.75’s, Strange center section, Moser 31spline axels, 29”Mt slicks, HRPARTSNSTUff anti roll system, Doug’s Headers 3.5” collectors, 22”Dynomax mufflers w/ H-pipe, Cliffs Q-jet, Fuel cell with sumps, Mallory 140 fuel pump and filter. Denny’s 3.5” drive shaft. |
'65. Probably GTO. MIGHT be "big car". Worth $100? Yes. Jim |
Definitely a 65 Intake. Definitely worth $100.00 (may be worth as much as $350.00 to the guy who needs a intake with the right casting date on the intake. For 99% of the other customers somewhere between as was said, $100.00 and $300.00 to buy.
A Bunch of the tri-powers would crack in the water cross-over area, I would strip the paint off the intake and do a very good inspection of the part. Cast Intakes are very hard to fix. When you remove the cross-over and use a different cross-over the price drops accordingly except for a racer who wants to run a tri-power. There are ALUMINUM Tri-Powers being reproduced therefore the demand for cast units has dropped a lot. Tom Vaught
It's a 65, the cast part number on it should be #9778818...
"Three may keep a secret, if two are dead" ~ Benjamin Franklin ~ |
