Old 03-15-2009, 01:20 PM
critter's Avatar
critter critter is offline
Default 4L80e, worth this price?
"I have a chevy 4L80E transmission for sale, its low miles and works well. I have the transmission, stand alone computer, wiring harness, software and carb. TPS adaptor (so u can run a carberated engine with this tansmission). I am asking $2200.00 OBO. There is NO torque converter"
That's a direct quote from his ad. I've got him at $1,800 now. Is it worth that much?
12.84 @ 106.89 with street radials.
12.63 @ 108.39 on drag radials.
Old 03-15-2009, 03:14 PM
Big Injun's Avatar
Big Injun Big Injun is offline
What controller (computer) is it? The controller is usually as pricey as the trans. The combined price sounds good provided the trans needs no work.
Dave "Big Injun" Anderson
dave@4mypontiac.com
www.4mypontiac.com
For GTO Celebration items click the tile coaster.
Old 03-15-2009, 05:23 PM
David Holmberg's Avatar
Great price, depending (as Dave said) on the computer that's included.
Old 03-15-2009, 05:42 PM
440GP69's Avatar
440GP69 440GP69 is offline
OK so a Used Trans, Ummm I'd say 1800 with the Converter as those are Real Exspensive from a Good Company Like PTC!, In Fact talk with Jake Shoe On here Before you buy a used one because he may be able to get you a new one all built up for that price
D.S.R.E. Your NW Pontiac Street/Strip Engine Builder, Specializing in Cylinder Head,Intake Manifold,and Exhaust Manifold Porting services and Building the Most Efficient stock rebuilds to Hi HP Pump Gas and Race Combinations for Pontiac,Buicks,Olds,FE Fords,385 Series and HP Gen 3 and 4 LS engines!
2006 silvy Z71 4X4,383 LS 600+hp NA
Shared Toy-66 Lemans 470cid by me 537hp 580tq-manifolds, 570hp 590tq-2"headers,custom cam,rpm intake, mild e-heads, Looks stock ;-}
Old 03-15-2009, 06:46 PM
Big Injun's Avatar
...but not with a controller. If the controller is one of the good ones like Compushift will cost you $1,000 - $1,400. So, as I asked, what controller. If one of the good ones, the price is right.
dave@4mypontiac.com
www.4mypontiac.com
Old 03-15-2009, 06:49 PM
critter's Avatar
It is a TCI controller, harness and TPS from what I can tell looking at photos. I'll call tonight to confirm it. The transmission is supposed to be a GM Goodwrench box trans that has about 2000 miles on it. Note that there is NO converter and the unit will have to be set up for a mechanical speedometer for my TA. More $$$ to me but I'd have to do that regardless of buying new or used.
Old 03-15-2009, 06:56 PM
critter's Avatar
OK, look here and see what you thing:
http://littlerock.craigslist.org/pts/1064595061.html
Old 03-15-2009, 07:12 PM
critter's Avatar
Update. I called and spoke to him. I misunderstood one thing. The transmission has under 10,000 miles on it. The transmission was a replacement for his buddy's Suburban from GM but he doesn't know what year it was. When the Suburban was wrecked they pulled the transmission and he bought it. The other parts are all TCI but that's about all he could tell me. I'll go look at it tomorrow. What should I look for?
Old 03-15-2009, 11:44 PM
jakeshoe jakeshoe is offline
The TCI controller is likely the older model, and you can buy those new now for $500 or less.
The new model TCI controller is made by PCS. About $800-850. Good setup. We just used one in a '68 Camaro with a 4L80E.
My 4L80Es are $2200 built using a new 34 element sprag, High Energy clutches, rollerized rear planet to case, fwd hub to direct drum, dual fed direct drum, new boost valve, valve body updates, new pan, and new bands. That includes the core charge for an early style core, which I prefer for most retrofits due to cooler line location.
I'll be looking into making my own mechanical speedo setups on the Bridgeport for the 4L80E in a few weeks to bring costs down on that. There is a Cable-X box you can use to convert the electronic signal to mechanical for less than $300.
I have also started selling converters with my 4L80Es as a package deal.
Excellent 9.5" units that can use the 6 bolt flexplate.
They are $475 with a trans purchase.
That should at least give you some idea of pricing.
$1800 isnt a bad price but I wouldn't consider a killer deal if its the old TCI TCU.
Old 03-16-2009, 03:15 AM
TTS's Avatar
TTS TTS is offline
SERTA unit with controller? I'd be maxed out to part with a grand.
A Government big enough to give you everything you want is strong enough to take everything you have. - Jefferson
"If ever a time should come, when vain and aspiring men shall possess the highest seats in Government, our country will stand in need of its experienced patriots to prevent its ruin." - Samuel Adams
Right and wrong doesn't need facts all the time.
-Lighthouseman ("lawyer")
Starnes Performance Automatics
www.Starnesperformance.com
Old 03-16-2009, 03:18 AM
TTS's Avatar
TTS TTS is offline
How much for the 80 and a purple converter? $2675?
Old 03-16-2009, 09:17 AM
HWYSTR455's Avatar
I'm currently using a Cable-X box, and the only thing I don't like about it is that
A) no speed in reverse, aka, no j-turns know how fast you're going!,
and B) on a fast accelleration, it take the speedo a fraction of a sec to 'catch up' to the speed, like, you'll get to 80 mph quick, look down at the speedo, and you can watch it go to 80!
Jakeshoe - for the speedo conversion, know what would be slick? Have a contained motor for the drive down by the trans itself, so you don't have to mess with short cables, wires, etc, would all be right down there where it needs to be. I've looked at the tail housings, nice, but pricey, and what if you want to go to an elec speedo? Maybe I'm just whining!
I will say that the 4L80E is the nicest auto trans I've every had in a musclecar, hands down. Shift characteristics, performance, and adjustability are all more than I could have ever asked for.
Old 03-16-2009, 09:38 AM
critter's Avatar
How would I know if it's the older or newer version of the TCI controller?
Old 03-16-2009, 10:57 AM
critter's Avatar
301002 is the number on the controller. Is that part number the newer controller? When I google search it I get to the FAST site with the same number. Is FAST making the controllers for TCI?
Old 03-16-2009, 11:48 AM
critter's Avatar
OK, to answer my own question, that part number is used by FAST when they sell a stand alone controller via FAST. It is a TCI branded box but their part number since FAST is a sister company to TCI, or at least that's what the TCI rep tells me.
Old 03-17-2009, 11:06 PM
critter's Avatar
Thank you to those who responded. I talked him down to $1,300 so I did purchase it. The TCI controller is the FAST unit and the harness is unmolested. The fluid in the trans was clean and did not smell burned. He had the linkages, software, etc. The only thing missing was the torque converter and the dipstick tube. Overall, I think it was a decent deal, so long as the transmission is OK.
