My First Nine Second Pass
Here is a couple of video links from a week ago Friday September 15 of my first nine second passes. I drive the car to the track and race it the same way I drove it there. Car is an 81 Trans-Am with an IAII 535 block, Butler Wide Port heads, 3.50 gear Moser Nine Inch Rear End, full exhaust system out the back, MT 325x50 Drag Radial, Cal-Trac bars, stock front suspension with 90/10 shocks, car with me in it weighs 3908. Car has no power adders, all motor !! Hope the links work
http://www.youtube.com/watch?v=ibV6EVp__rQ http://www.youtube.com/watch?v=G3GopfVHO8s David K |
Awesome ! Great job on your car. Another Pontiac street terror !
68 Firebird Are you running with the wind or breaking it? |
Dave - very impressive and congrats !!
I like the launch - what were your 60 foots ?
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
David-
That is awesome, brave driving it to and from. What does the car 60ft? John |
Thanks for the replys !! Car really drives nice on the street, untill you punch it !!
The car usually 60 fts in the 1.51 range, that night with a different dominator and good air it ran two back to back 1.46 60 foot times. |
What stall you runnin? Thats about where I want mine to run, if I ever get back to working on it.
Congrats Dave, I know you've worked hard for this!
How well do the 325's fit on your car? I've run 28x13.5 QTP's on 10 rims (5.5 BS) on mine, but would love to run those DR's. |
Very impressive Dave. Nice, clean car! Congrats...that thing is bad a$$!!!
East Coast Mafia TTFMF Making CVWHAT's great again. I guess it took a deplorable ECM member to do it! Quote:
Fastest Blow-thru Pontiac powered car in the Country 8.440@166.97 (3465lbs) Fastest Pontiac CV-1 car on the planet with only 6 passes on the combo: 4.80@147.65/ 7.49@180.12MPH (3365lbs) |
The converter is a Continental 10" that I had built for my 461, it flashed to 4100 rpm with that engine. I decided to use it for my 535, it now flashes to about 4700 rpm and I go through the traps at around 6200 to 6300 rpm at 137 mph. Slip is around 5 percent, I need to have a higher flash stall and I am about to change the gear from the 3.50 to a 3.89. I currently shift at 6800 rpm so I think the 3.89 should optimize my trap rpm.
The 325x50 MT Drag radials fit great and usually hook pretty good, this may change when I go to the 3.89 gear. Over the winter I want to upgrade my front suspenion. Thanks so much for the comments !! |
Very impressive car! Nice Job, and Congratulations!
Nice job. I'm planning a 535 build for my street car with plans to get it in the 9's. What cam are you running if you don't mind me asking? I've got the crank and soon will be getting my BME rods, pistons, and some wideports. Debating on what cam to run.
65 Lemans Street Car - 521, T400, 3.70 9". 10.13 @ 135. 3770 lbs. Drag Week ‘14, ‘15, ‘17 63 Lemans Race Car- 8.81 @ 151, 5.60 @ 123(SOLD) 67 Bonneville ragtop 74 Firebird - 455, e heads, TK0600 in process |
Cool!
Tempest455 |
Very nice and its a STREET MACHINE too.
The Bandit Rules - Make mine with a SD-455 Engine . |
Thanks again guys for the comments !! Car does seem to get noticed at the track and people are surprised when they see a Pontiac engine in there.
The cam is a Comp Cams solid roller with 280/288 duration at .050 with a 112 l/c and is installed at 108.5 degrees. Dave forgot to mention that the 325/50 MT Drag radials are mounted on 8" rims with 4.5" back space, I would like to get some 10" rims. Jim Hand runs the same size tire on his wagon with a 10" rim that he said I could borrow to see how well they fit. |
awesome runs Dave!! love to see 9 second T/As.
Conrad 79 Trans AM 406 #12 heads Torker II intake Crower 60210 750 holley vac. sec. T400 3500 Stall 3:73:1 rear. ECMTTFMFers. IHTTFMFers. |
It doesn't get much better than driving to a race, running a 9 second pass and driving home. I had a friend w/ a blown 427 Camaro drive 50 miles to the track, run 9.90's all day and even won Best in Show on the show side and then drive it home. Very hard to do!
Dave posted your vid on www.transamcountry.com PONTIAC POWER.
Dave do you have some pics of your T/A--I think we'd all like to see them.
Wareagle,
Thanks for posting the link on the other site, interesting to see other peoples response to the car. I will try to get some pictures of the car posted up soon when I get a chance to get it out of the garage. It is no show car for sure, it still has the original paint. |
I also posted vids of this 75 T/A .030 455--Totally cool.
http://youtube.com/watch?v=2YXR8x1Y1...elated&search=
