Rear Main leak 350 V8
Friend has a 350 v8 Pontiac that has rear main leak. Does anyone have a remedy for this other than engine removal? Thanks, Frank69
I did it in my '69 GTO, only once, back in the early .70's.
Worked just fine. I then raced it in '73 & '74, having never removed the engine. But, I was MUCH younger then. Wouldn't attempt it now. Would pull & try a 1-piece seal. Most say they work good, in most engines. |
Thanks for the info.. Good suggestion. Frank69
Thanks for the info. Good suggestion. Frank69
I have not had any failure with the BOP 1 pc seal.50/50 with the 2pc.Tom
I would verify it is an actual rear main seal leak 1`st. Oil pans are famous for leaking back there. Valley pan, dist gasket, etc.
The Following User Says Thank You to PunchT37 For This Useful Post: | ||
After close inspection it looks like both valve covers are leaking down back side of engine. Thanks Punch T37! Frank69
