Old 09-13-2021, 11:58 AM
tdavidl's Avatar
tdavidl tdavidl is offline
Originally Posted by 78w72 View Post
this is common on q-jets. all my cars with late 70's q-jets do this, i can feel it in the pedal when the secondaries just start to open. no cable or pedal bushing binding, it just takes a little more force to open the secondaries.
not saying that is your issue, its a good idea to check all the things mentioned above, but if there is no binding in the cable or pedal bushing issues, it could just be the resistance of the secondaries youre feeling.
thx...just started after the recent rebuild so you may be right
71 Formula 400, Castillian Bronze, Saddle Interior:
https://youtu.be/cfEv-1vKc0k
Old 09-13-2021, 12:02 PM
tdavidl's Avatar
Originally Posted by Joe's Garage View Post
To test for this being the problem, hold the choke blade fully OPEN and check the throttle action under the hood.
The lockout is on the passenger's side and is not difficult to disable. The secondary throttle blade lockout, AND the secondary flapper lockouts on the earlier carbs are removed or disabled as standard procedure whenever we work on a quadrajetjet.
Here's a video:
https://www.youtube.com/watch?v=_mwX06-3LV8
Good luck!
thx, yea, that's not the issue since its happening all the time, same spot on pedal push all the time
Old 09-13-2021, 12:03 PM
tdavidl's Avatar
Originally Posted by JLMounce View Post
I recently had a similar thing happen, but it was hanging on throttle close. Verified at the TBI, no issue, but at the pedal there was a bind. Turned out to be the factory cable was fraying inside it's sheath near the peddle assembly.
If it's the original cable, it would be worth removing and inspecting the movement of the cable within the sheathing to verify that's not the cause.
I replaced with a Lokar cut to fit cable which is very nice.
thx, another item on my list to check :-)
Old 09-13-2021, 12:06 PM
tdavidl's Avatar
Very easy way to check throttle cable and pedal linkage vs blame the carb is to remove the carb return spring and the throttle cable from the carb.
Tom V.
thx, another thing on my list
tdavidl's Avatar
Originally Posted by redbird68 View Post
had the same issue on my 69 goat 4 speed, very annoying especially with a clutch. the pedal would move easily for say an inch then hang and when i pushed through it the engine would rev.
replaced the cable, i think around $25 and smooth as butter. install took maybe 15 min
amazing difference in the enjoyment of driving the car
thx
Old 09-13-2021, 12:09 PM
PunchT37's Avatar
PunchT37 PunchT37 is online now
It should be the carb since the problem popped up after the "repair". Been reading the replies. I don`t think the accel pump or pump rod binding has been mentioned. Rod could be installed incorrectly.
Old 09-13-2021, 02:07 PM
ta man ta man is offline
Check carb gasket interference also.
