I have a 1970 posi out of a catalina and am thinking of putting it into my 66 bonneville. Is this a bolt in or are there changes that need to be made to make it work. Thanks!
The light at the end of your tunnel is just a freight train coming your way - Metallica
The light at the end of your tunnel is just a freight train coming your way - Metallica |
The differential case will fit your carrier but may not fit your ring and pinion ratio.
I looked at some of my manuals and the Motors manual say's that you might have a C clip rear from 69-76. My Chiltons manual says that the rears are the same from 65-70. My advise to you would be to pull both and set them side by side and compare.
RDRR Custom Fabrications ....A fictitious company doing fictitious work.... |
